It is currently Mon Oct 12, 2026 8:08 am
PostPosted: Tue Aug 25, 2009 2:01 pm
It's been over a 6 month wait, but they finally showed up. We ordered them from Crower, but we ended up with Carrilo's. ??? Anyways the rods are 7.100" going on an offset ground 225 forged crank with a 4.30" stroke, 440 billet main caps with 3.42" bore custom Ross pistons. Ross sent us 8 pistons BTW. lol The block is partial filled and it took some time and effort to clearance the rods at the bottom of the cylinder walls. The blower short block is together so now we need a camshaft.
Anyone know any cam vendors that carry SL6 cam cores for a custom grind?
PostPosted: Tue Aug 25, 2009 2:27 pm
Site Admin
Oregon Cam grinding for cores.
New blanks would be Erson and Comp Cams.
Erson had a time of getting cores for a while, but may have solved that.
CJ
PostPosted: Tue Aug 25, 2009 4:00 pm
Oregon Cam Grinding did have some new /6 blanks last time I called. They were round lobe blanks so you should be able to get just about anything you could possibly want, but the grinding cost is higher than a reground plus the cost of the blank.
PostPosted: Tue Aug 25, 2009 7:56 pm
where's that thread with the turbo cam advice?
Users browsing this forum: Rick Covalt and 24 guests
