It is currently Mon Nov 30, 2026 3:54 am
PostPosted: Thu Sep 10, 2009 11:26 pm
which Comp Cam do people prefer or suggest for a mild slant 6 rebuild using the oversize valves, and running the standard BBD carb ?
Comp offers the 252S and the 264S.
which one should I choose?
Installed into an old '68 Dart sedan-
68 dart -4 doors with house paint, dents, satellite radio, and no rust
67 coronet -4 doors, quarter million miles, currently retired and growing older in the yard
73 charger -2 doors big block car, prowls phx in winter, sits inside during summer
PostPosted: Thu Sep 10, 2009 11:40 pm
None.........
Slantsix.org has a deal with erson for discounted cams.
Also Doc developed some special grinds with them.
The cam experts will chime in, but I'd say the special RV10 or RV15.....
(depending on your driving style, amount of build(compression ratio), automatic or manual,......)
PostPosted: Fri Sep 11, 2009 5:45 am
Need more info. about the build.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Sep 11, 2009 6:07 am
My main questions always revolve around the trans - stick or auto, and will you use a higher than stock stall converter. 252S is almost indistinguishable from stock. 264 will be a bump up. Erson cams are probably better.
 Post subject: Erson has NO cores
PostPosted: Fri Sep 11, 2009 9:49 am
phoned John @ Ersons.
as of today, they do not have SlantSix cores to work with.
decided to order from Oregon cams instead. thx-
PostPosted: Fri Sep 11, 2009 10:11 am
OregonCams is a great idea. I asked pretty much the same question before when I was starting out and they gave me the 819. I can never seem to find it but Joshie225 posted the cam information they grind around here somewhere.
My suggestions for a relative stock setup would be in the 260Dur, .4X lift range, and 110-112 LSA. Good Luck, Wes
Users browsing this forum: Bing [Bot] and 5 guests
