It is currently Sat May 02, 2026 6:12 pm
PostPosted: Fri Sep 11, 2009 10:24 am
Anybody know how close the spring perches are on an F/J/M body rear to an A-body? Will it bolt in? I think the track is close to a '66-'70 B-body, which fits right into my plan.
I'm gonna use a '73-up disc set up on a '68 Dart, then use a wider rear end to make the track nearly the same in the rear.
Then I can run 4 of the same wheel with a fairly high offset.
Thanks.
Brian (Valianator)
'65 Valiant V100 170/T-flite
'82 D150 225/4-speed
'65 Dart 225 4 door
'68 Dart 225 4-door with Valiant front clip (future project)
PostPosted: Fri Sep 18, 2009 8:42 am
here's your axle width info...
http://www.carnut.com/specs/rear.html
Check it out... www.symcoshakedown.com
PostPosted: Fri Sep 18, 2009 10:09 am
Thanks.
I recently parted out an 80 Cordoba that had a 70 B Body 8.75 installed. I didn't see any issues when I removed the rear end. It's available with or w/o gears (2.94 peg leg).
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Fri Sep 18, 2009 11:29 pm
The F/M/J spring perches are 1 inch farther apart than the A-body. Mopar Muscle did an article where they put an M-body rear in an A-bomb.
If the new axle has a different diameter ring gear than the one you're pulling out, you'll need to change the driveshaft. Typically, this means to shorten it, but not always.
The 64-66 Mustang, 75-80 Ford Grenada/Mercury Monarch have the same spring perch spacing as the A-body. The 8 inch is okay, the 9 inch is better. Avoid the 8.8 inch. The holy grail of this source is a complete Lincoln Versailles assembly. It is a 9 inch rear with disk brakes. The Versailles was made from 77-80 in very small numbers. Good luck finding one in a salvage yard cause the Ford guys are after them, too.
You can't fix stupid. - Ron White
 Post subject: Thanks for the info.
PostPosted: Tue Sep 22, 2009 7:20 pm
Thanks for all the info, guys.
I just snagged a '65 B body 8.75, so it looks like that's what I'll be adapting 8)
Brian (Valianator)
'65 Dart 225 4 door
