It is currently Mon Oct 12, 2026 5:51 am
 Post subject: Aluminum intake manifold
PostPosted: Tue Oct 13, 2009 9:08 am
Hello all ,
looking for your input on a Aluminum intake manifold 1bbl for my slant 6 225 rebuild , i have a chance to pick one up , it is the casted Aluminum 1 piece , i want to keep my van rebuild with the original configuration as close as possible , let me know what you all think ~~`thanks :D
PostPosted: Tue Oct 13, 2009 9:12 am
There were two types of aluminum one barrel intakes made for slant sixes. One was a two piece design, the other was a one piece design. The one piece design came on 80s era trucks and vans and is the better design. The two piece design came in the late 70s/early 80s and is known to have problems with air leaks on the poorly welded seam.
That being said, a good thick layer of paint might be all you need to seal up a two piece model. You should also be aware that the aluminum intakes are known to crack directly below the carb in the "hot-spot" where the intake and exhaust manifolds meet, right around the EGR port.
PostPosted: Tue Oct 13, 2009 9:30 am
Five. ('60 sandcast, '60 semipermanent-mould cast, '76 Feather Duster/Dart Lite 1-piece sandcast, '78-'82ish 2-piece EB-welded, '82ish-up 1-piece sandcast)
PostPosted: Tue Oct 13, 2009 9:45 am
:oops:
True, but the chances of seeing the 1960 pieces are slim to none, same with the Feather Duster intake. Yeah, that's my story and I'm sticking with it. :wink:
PostPosted: Tue Oct 13, 2009 11:20 am
thanks for your input ~~ it is the casted aluminum 1 piece not the welded or 2 piece type
PostPosted: Tue Oct 13, 2009 2:23 pm
I am running one and love it. It warms up real quick on cold mornings.
Click on the red link below my name to see pictures of it. It is a very heavy thick casting I found on a 82 truck.
PostPosted: Wed Oct 14, 2009 9:12 am
just wanted to say thanks for the input this site and you guys are awsome , ted hot looking motor my friend gives me inspiration :D
PostPosted: Wed Oct 14, 2009 9:33 am
Not as nice looking as Teds but this one is in a van
PostPosted: Wed Oct 14, 2009 7:27 pm
6shotvanner great looking motor thanks gives me inspiration and motivation to do and go thru my van the right way :D
Users browsing this forum: Google [Bot] and 19 guests
