It is currently Fri Nov 13, 2026 9:32 pm
 Post subject: No charge
PostPosted: Sat Nov 07, 2009 7:19 pm
I noticed that my alternator was not charging, after noting that it was charging only a day or two before. It tested bad in an off-the-car test. I replaced it. I still saw no charging. I installed a new regulator. It still isn't charging. The battery holds a charge well when I pump it up with a charger. I don't even know where to start. Suggestions?
With the regulator was a note saying NOT to try to polarize it. I'm not even certain what that means.
I'm a little puzzled by the new alternator. The old one has a heavy output screw terminal near the top and what I assume is the field terminal lug at the bottom. This one also has an upper lug similar to the lower one. Can anyone please explain the extra terminal?
RK
PostPosted: Sat Nov 07, 2009 7:32 pm
The alternator you got, is a "dual Field" unit, for the later cars/trucks. It will work on the early single field wire cars, by conecting the "extra" terminal to ground.
PostPosted: Sun Nov 08, 2009 6:03 am
The alternator you got, is a "dual Field" unit, for the later cars/trucks. It will work on the early single field wire cars, by connecting the "extra" terminal to ground.
So you say and so it be!
Thanks a million just from me!
RK
