It is currently Sat Nov 14, 2026 3:34 am
 Post subject: sources for supplies?
PostPosted: Wed Nov 25, 2009 11:09 pm
Where can a person get good quality crimp connectors and such. I hate the cheap crap that is sold in most of the of the chain stores. Also, can the factory bulk head wires be removed from the plug-in part of the bulkhead connection? Can a person find the crimp on ends to go back into the bulkhead? What kind of connectors did Mopar use on our old slant powered cars? (was it standard or just used on chryslers?).
I know this is a lot of questions but I am on a mission to try to rejuvinate the wiring in the ol' W150. Trying to reduce the voltage drops.
(I found a nice DMM at a pawn shop too.)
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
PostPosted: Wed Nov 25, 2009 11:13 pm
I have successfully removed many terminal from bulkhead connectors. You need a thin flathead screwdriver of the sort found in jewelers screwdriver sets or on Leatherman tools. Very very thin. To remove the terminal you must bend the small tab on top of the terminal and inside the housing down and the terminal slides out the back.
PostPosted: Thu Nov 26, 2009 6:21 am
Contact Kimberly Patterson, at Terminal Supply Co. 1800 Thunderbird, Troy, Mi. 48084. KPatterson@Terminalsupplyco.com
800-989-9632
Tell her Charlie Schmid from C & S Performance & Racing sent you. They have treated me real well. I made contact with them last year at the PRI trade show.
 Post subject: terminal connectors
PostPosted: Thu Nov 26, 2009 2:14 pm
I have found a nice selection of tin plated copper terminal connectors at
elecdirect.com
wiringproducts.com
mouser electronics has a huge selection of all kinds of electrical - electronic components.
these three all give bulk discounts but will also sell one or two units to consumers like us.
PostPosted: Thu Nov 26, 2009 3:21 pm
thanks for the replies guys. Ceej thanks for the tip.
1979 W150 Shortbox
The Good Life.
PostPosted: Sat Jan 16, 2010 11:47 am
The original connector shells and crimp terminals were from Packard wire, They are still available. Waytek wire caries them. Search for packard series 56.
http://order.waytekwire.com/cgi-bin/lan ... (S0020):01
Here is a link:
http://order.waytekwire.com/products2/M ... onnectors/
They carry the crimping tool:
http://order.waytekwire.com/productdeta ... NG%20TOOL/
And the removal tool, which prevents lots of swearing:
http://order.waytekwire.com/productdeta ... AL%20TOOL/
Their pricing on terminals is very reasonable and it is well worth buying the correct crimp tool to do the job right.
Maybe we should make this a sticky?
Scott M
