It is currently Wed Jun 17, 2026 10:33 pm
PostPosted: Sun Dec 06, 2009 10:34 pm
Hi I posted in June, putting together a 225 in a Coronet 440. Then I got hit by a car on my motorcycle, after hospital and recovery I'm back at it!
I suffered 2 broken wrists and a broken pelvis... lost some flexibility in the hands.
I can't remember wich way the oil slinger faces? I had the motor rebuilt after getting good advice from here and Doug D. My sister works for Franklin auto in Redding, Mark did a beautifull job, unleaded seats new valves, 10 over on the pistons! Putting it all back together now. Once I get the head on and valve train installed, what the the best process for priming, start-up and break in? Its been years!
thanks Vic :shock:
Cudaman, 1965 Cuda, 1967 Coronet 440 1962 Imperial
PostPosted: Sun Dec 06, 2009 11:41 pm
6 Pack Dart
Slinger faces with the outside towards the timing cover. If you try to put it on the other way it will rub on the chain.
 Post subject: Oil slinger
PostPosted: Mon Dec 07, 2009 12:48 am
Thanks, makes sense ! :D
PostPosted: Mon Dec 07, 2009 8:27 am
I was wondering what happened to you and your project...
It is good to hear that you are healing and that the project did not go by the "way-side".
Did the head get some port clean-up work while it was apart?
Keep asking detailed questions, work on it "bit-by-bit" and you will have this car going in no time!
 Post subject: Head
PostPosted: Mon Dec 07, 2009 10:00 am
Hi, I forgot about that? I was in the hospital when I had the work done!I am putting on the head and oil pump this week.!
Thanks. Not sure how post pics?
PostPosted: Mon Dec 07, 2009 10:12 am
If you want me to take a quick look at the head prior to install, send me a PM so we can schedule something.
What do you have for an oil pump??
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
