It is currently Thu Oct 22, 2026 6:17 am
PostPosted: Wed Jun 26, 2002 8:39 am
I have a '66 plymouth belvedere that has a nice
running slant 6 , I want to put a comp cam in it.
And am wondering if it can be done with the slant still in the car, took a look at it and it dont look like it would be to bad...
Demonboy71@yahoo.com
PostPosted: Thu Jun 27, 2002 11:41 pm
: I have a '66 plymouth belvedere that has a nice
: running slant 6 , I want to put a comp cam in
: it.
: And am wondering if it can be done with the
: slant still in the car, took a look at it
: and it dont look like it would be to bad...
You should be able to do it in your Belvedere,
I have done it in a number of A-Bodies so the full size car *should* have more room.
It is best to take some measurements seeing that the SL6 camshaft is 25 1/2 inches long,
lots of stuff can get in the way.
See the link for some PICs and info. on the in car cam swap I did on my 64 Dart.
Cam Swap Info.
This really depends on the car in question...some of them, if you remove the radiator and grill, you have a clear shot at the cam exit path. Others...no way!
redbear@vrx.net
PostPosted: Fri Jun 28, 2002 12:49 am
If you have air conditioning, the condenser might be in the way.
: it.
flturbo6@aol.com
 Post subject: Re: In car camshaft swap
PostPosted: Fri Jun 28, 2002 10:13 am
: You should be able to do it in your Belvedere,
: I have done it in a number of A-Bodies so the
: full size car *should* have more room.
: It is best to take some measurements seeing
: that the SL6 camshaft is 25 1/2 inches long,
: lots of stuff can get in the way.
: See the link for some PICs and info. on the in
: car cam swap I did on my 64 Dart.
: DD
Thanks guys,
My belvedere is a non-ac car so it shouldnt
be too bad. Mike
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 24 guests
