It is currently Wed May 20, 2026 11:12 pm
 Post subject: electric lock up switch
PostPosted: Fri Apr 16, 2010 5:30 pm
hello. my sons 86 D100 has a elec. lockup as indicated by the extra connection at left rear corner of trans, lean burn removed. i believe i read a post some time ago about using a chevy vac. switch? sorry if this is repeat question, didn't find anything with search. thanks, andy.
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
PostPosted: Mon Apr 19, 2010 6:04 pm
hump de bump
PostPosted: Wed Apr 21, 2010 5:15 am
See this post. http://www.slantsix.org/forum/viewtopic ... ht=#258846
PostPosted: Wed Apr 21, 2010 5:01 pm
thanks. since this is for my kids truck, i am hoping to make it "idiot proof" so he doesn't have to toggle manually. if i recall from something i read here if you shift into lockup during hard acceleration it may burn up the lockup clutch. i am considering swapping the hydraulic lockup in my truck with his electric. do you know if you can use a high (2800-3200) stall electric lockup converter? my sons truck is basically stock, but i am building a fairly strong 225 for mine and like the idea of manually selecting lockup. have a great day, andy.
PostPosted: Wed Apr 21, 2010 8:21 pm
try this site I use an adjustable hobbs switch on cummins for lockup there about 26-28 $pn 76053. then use a vacuum switch on a gas to avoid WOT lockup http://www.transmissioncenter.net/SwapInformation.htm
Nick
86 d150 turbo /6.
PostPosted: Thu Apr 22, 2010 1:49 pm
thanks nick. good reading. since i have a 904 with no overdrive, the part #71V2 from that site seems to be a good choice since i can adjust the switch to close at the vacuum point that makes the lockup behave to my liking. i will see if napa has a similar switch since i get a discount there as i buy a lot of stuff for my job there. that should squeeze a few more mpg out of the truck. thanks again, andy.
