It is currently Mon Nov 23, 2026 10:06 pm
PostPosted: Sat May 08, 2010 4:10 pm
I recently acquired a 1972 Dodge B200 Tradesman van. It has a Slant six that hasnt been run in some time.
I got it to fire today and while I was spraying the carb with carb cleaner to keep it running,I noticed smoke coming from the side of the engine where the spark plugs are.
Did some investigation and came to the conclusion that 1 of the spark plug tubes (#6) is MIA. I know that the smoke may indicate blow by but im not too concerned about that at the moment.Ill concern myself with those issues later,once I can get the vehicle run on its own without the aid of Carb cleaner sprayed into the throat of the carb.Then ill do the fine tuning thats necessary
Where can I get a replacement tube(or even a set)? There was no smoke coming out of any of the other ares by the spark plugs as the tubes were all installed as they should be.
Ive done some searching and can only find the sets of seals for the tubes,nut the tubes themselves.
Can anyone point me in the right direction?
72 Swinger Special Originally a 3 speed 198/6 car now has a 225 with the 3 speed
72 B200 Shorty Van 225 /6
4 other Fullsize Mopars from 65-73
PostPosted: Sat May 08, 2010 8:34 pm
Doc has a sh-t pot full of them. If you ask real nicely he may be able to help you. :wink:
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Sun May 09, 2010 6:27 am
I see that you're in Arizona; if you're anywhere near Gilbert or Sky Harbor I can get a spark plug tube to you. Send me a PM.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
