It is currently Fri Nov 20, 2026 12:42 am
 Post subject: Spec Clutch Problem
PostPosted: Sun May 16, 2010 7:36 am
Just installed diaphram style 9 in kevlar unit. I have not called Matt yet but this unit slips bad trying to accealerate in 2nd gear. If I feather trottle I can get in to 3rd but give it any power and the motor just breaks away. I do not think this is the answer to our clutch problem kevlar disk dosn't seem to have enought friction material and diaphram cover not enought pressure. Has anybody else got one in car and working. Yes I have 1/4 in clearance between throw out and fingers on plate and flywheel was machined and cleaned along with cleaned pressure plate surface. I am going to call Matt monday will try to post after that
PostPosted: Sun May 16, 2010 9:33 am
Just asking, but why would you expect a 9" clutch to hold a blown motor no matter what it's made of? :?
PostPosted: Sun May 16, 2010 10:16 am
I have a 9.25" kevlar unit (last of the McLeod)
I use a stock 9.25 diaphram and flywheel.
My car makes mebbe 175hp and has 3.55 gears. Car weight 3000lbs
I usually let the clutch out at an idle ,,,,,then nail it.
I can do burnouts with it as long as Im assured wheelspin (235/60/14)
Its fine for anything other than a hooked up launch......
If you smoked it even once you will need to start over.
PostPosted: Sun May 16, 2010 10:48 am
If you read about Spec Clutch around the 'net you'll find that many people have slipping problems. I think that Spec overrates the torque capacity of their clutches. Still I ordered a 9" clutch from Spec Monday the 10th, but having read other people's experiences I went with a 6-puck metallic disc. My engine also is normally aspirated and just 174ci (it's +.040" overbore 170) so it will make a lot less torque than a blown 225.
I had a full Kevlar faced 9 1/4" clutch disc with a Borg and Beck cover before. Even with 9 springs in the cover (instead of the 6 stock springs) it was marginal behind a mild 318 (222hp and 249 ft/lbs at the rear wheels). This is another reason I did not choose Kevlar for my new clutch.
 Post subject: Re: Spec Clutch Problem
PostPosted: Sun May 16, 2010 5:27 pm
I think spec rates this clutch package at 550 ft lb with it breaking away at 1/3 throttle I should quit my day job and bulid supercharged engines cause I must be makeing over 1500 ft lb. Seriously ether I have a defective piece or its junk.
PostPosted: Sun May 16, 2010 6:15 pm
Site Admin
I did a center-force clutch on an over-baked big block to solve problems like your having. At WOT it would break loose fully engaged as the engine spun up. The center-force didn't break loose. Ran it for many years.
2¢
CJ
PostPosted: Tue May 18, 2010 2:23 pm
Have you contacted Spec about your clutch problems yet? I just got my clutch from them today. It's really 8 7/8" or 225mm. As I wrote before I bought the 6-puck metallic disc.
