It is currently Fri Nov 20, 2026 7:20 pm
PostPosted: Thu May 27, 2010 6:12 pm
Bought a 1980 pickup for the slant 6 and 4sp. overdrive. Less than a week later I had a chance to buy a short tail shaft 833 od supposedly
from a 1977 f body. The output shafts are of different diameters.
1 1/4" versus 1 1/16" for the short tail shaft. Will a 1966 valiant yoke and driveshaft fit the smaller output shaft.
PostPosted: Thu May 27, 2010 7:12 pm
Yes, the smaller slip yoke from the '66 Valiant should fit the small output shaft A833OD just fine. I don't know if the driveshaft will fit because you didn't say what the vehicle is or if anything other than the transmission (like the rear end) is being changed.
PostPosted: Thu May 27, 2010 9:12 pm
Joshua, thanks for the quick reply. I forgot to mention that the Valiant will have a 8 inch ford rear end out of a Maverick. I would like to use the Valiant drive shaft and have the rear U joint changed to the ford type.The car now has a 230 3 speed with the overdrive type bellhousing.
PostPosted: Thu May 27, 2010 9:48 pm
So the car is a '66 Valiant? The Maverick rear end should be fine as long as the driveshaft doesn't bottom out in the trans. When you have the Ford U-joint put on the back of the driveshaft you might have it shortened 1/2".
 Post subject: Yep...
PostPosted: Fri May 28, 2010 6:28 pm
Just as an FYI for on lookers...to clarify Josh's train of thought.
The 1975-1976 A-Body A-833OD's seem to have the 29/30 spline output shaft for the A-727 yoke, as well as all the Truck long tailshaft boxes... Somewhere about 1977-1978 Mopar decided that the A-904 25/26 spline yoke should be the key for the (A)/F-body A-833OD trannies. So keep this in mind when buying a "yard" tranny, that you may need a different yoke to make the conversion work depending on your current tranny.
Note: I did see one guy at a yard try to sell one to a guy by jambing the 30 spline yoke into the back of the 26 spline tailshaft and tell him it fits fine...after they couldn't get the yoke out, i picked the tranny and yoke up for cheap...take the time to count the splines, before thinking the yoke just needs a bit more of a push.... :wink:
PostPosted: Fri May 28, 2010 7:01 pm
DI is right.
Also, I have a couple of '66-'67 A-body A833 4-speeds. These have 26 spline main shafts too.
