It is currently Tue Oct 13, 2026 10:31 pm
 Post subject: Sagging Door...
PostPosted: Mon Nov 01, 2010 10:29 am
The sagging driver's side door on my Volare coupe has gradually gotten worse. I bought one of those pin/bushing kits from an auto parts store, but this is something that I've never done before. How much of a PITA is this going to be? Suggestions?
Thanks!
Wes
'78 Volare 225
'67 Charger 318
PostPosted: Mon Nov 01, 2010 4:24 pm
Sounds like you need to do a hinge/alignment adjustment also. Maybe even just check the tightness of the bolts.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue Nov 02, 2010 9:12 am
You'll need a jack for under the door and a helper to hold and position it. Make sure you put some grease on the bushings before you get them in. They are a tight fit and you don't want them breaking. I tapped mine in very carefully with a hammer but if I had to do it again I'd build a little press out of some thread, nuts and washers. It's a cheap piece of maintenance that will make a ton of difference.
PostPosted: Tue Nov 02, 2010 11:11 pm
I ordered a set of A body pins and bushings for my Aspen. I haven't tried them yet. I hope they fit as I couldn't find any that said F-body on them. I shimmed door up to pinstripe it to keep the pintripe line straight with body line. We will see days off if they fit.
Thanks Mike
PostPosted: Thu Nov 11, 2010 1:48 am
Try your local hardware store, if it is the old-fashioned kind, or any building material outlets; ask for hinge pins or hinge bolts. I found ordinary house door hinge pins that fitted my Aspen perfectly when boring out the holes a little bit, and adjusting the length.
I also suggest to use lubri-plate or similar dry(ish) lube on the hinges, I found that grease has a tendency to accumulate a lot of road crud, it was all grainy when I wiped it off. Don't forget to lube those star-wheels!
Those hinges are really a very bad construction, the surfaces that takes the load are way too small, so a bushed pin may be better. They are also the main reason for rotten floors in F/M/J-bodies.
Olaf.
Aspenized
 Post subject: Re: Sagging Door...
PostPosted: Fri Dec 10, 2010 1:41 am
Thanks!
Wes
hi wes :wink: i always bought through online store my auto parts at (removed by Mod). I recently purchased an bushing kit.very cheap and affordable prices. :D
