It is currently Mon Nov 16, 2026 11:23 pm
PostPosted: Mon Mar 14, 2011 7:11 pm
Does the pin sit in the shaft groove and then press the reluctor down..hoping they are aligned? or press the reluctor down with the slots aligned (hopefully) and then install the pin?
Any tricks to getting the slots aligned?
Also, shaft doesn't want to come out. Stops when it is flush with the bottom of the dist. housing. I took off the burrs around the gear pin hole and cleaned it and very light emery cloth. Should I use a drift?
Thanks for the help
Super Six Conversion Stromberg
 Post subject: Yep...
PostPosted: Mon Mar 14, 2011 7:42 pm
I find it easier to install the reluctor with the pin installed in it halfway...
Get it fairly close then adjust (maybe I just have strong hands...).
If you get it to seat correctly, you can use a socket as a 'die' to seat the reluctor and the pin correctly. Worse case is using a drift but use a small (like 8oz) ball peen hammer...tap not drive.
Good luck,
PostPosted: Mon Mar 14, 2011 8:22 pm
Thanks D.I..
What about a difficult shaft that won't come out easily?
At first it would only go up until it hit the drive gear pin hole so I filed the burrs off around the hole.
Cleaned it with chemtool to get the crud off and then did a light emery cloth.
At that point it would go up just until it was flush with the bottom of the housing but that was it.
Should I maybe oil the end that I hit with the cloth?
Any problem with a light tap on a drift?
This is a dizzy that I grabbed out of a 77 Aspen that seems to have zero shaft play. I wanted to see how a stock curve comppares to the dizzy that you have helped me to get "closer" to what I need.
Thanks again, you're knowledge in this aea is invaluable.
PostPosted: Tue Mar 15, 2011 5:33 am
61 V200,
That reluctor is aptly named, as it can be reluctant to come off its shaft when a distributor has been sitting around for a while …
The first time I tried to disassemble my Dart’s distributor for a recurve it took an hour or more, and quite a long time to put it back together as corrosion made manipulation of its parts difficult. By the third or forth cycle of disassembly and reassembly the reluctor and the other parts began to corporate, and the process only took only a minute or to.
You are on the right track by cleaning, de-burring, and lubing the shaft and the parts that slide on to it. But be genital, and try not to lose the shiny surfaces. I found that “0000â€￾ steal wool was abrasive enough to brake most of the crud, and rust off, but not aggressive enough to damage the shaft’s polished surface.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DuckDuckGo [Bot] and 8 guests
