It is currently Mon May 11, 2026 6:42 am
PostPosted: Sun Jun 26, 2011 7:09 pm
I have a friend with a 72 duster that has the small bolt pattern kelsey hayes disc brakes is there any way to change the hub and rotors so he can go with big bolt pattern? Or is he going to have to switch out to the 73 and later spindle, hub, disc, rotor and calipers?
PostPosted: Sun Jun 26, 2011 8:12 pm
The spindle and everything attached including the lower ball joints has to be swapped for the '73+ parts.
PostPosted: Mon Jun 27, 2011 6:31 am
You may be able to use a Kelsey Ford hub and rotor with Mopar bearings.
Best way is to go 73 up......
PostPosted: Mon Jun 27, 2011 10:53 am
See here.
(also here, but that sounds like a more costly solution)
PostPosted: Wed Jun 29, 2011 7:02 pm
Thanks every one for your help. As always very usefull. I think I have my friend talked in to keeping his small bolt pattern. The reason he wanted to change was because he thought he wanted to go with disc brakes in the rear and I talked him out of that and in to keeping his 10 drums.
PostPosted: Thu Jun 30, 2011 5:17 pm
Keep in mind, though, that there IS a small-bolt pattern disc brake option out back if he has the 8 3/4" rear end. About $600. Talk to Cass:
http://www.doctordiff.com/
vm
