It is currently Wed Oct 07, 2026 9:03 am
PostPosted: Tue Jul 05, 2011 1:44 pm
is there a rattle can paint that is stock for an intake?
I scored a 2 barrel intake/carb of a 1976 Volare 2day
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Jul 05, 2011 2:04 pm
Correct color depends on year and application. See here. Most of them are available in rattle cans.
PostPosted: Tue Jul 05, 2011 3:30 pm
SSD
Im a little confused. the list reads my notor should be red, but it looks originial stock blue and get this the valve cover is blue over red..??
I took pics. of the numbers on the drivers side on the block
do these give the year?
slant six's RULE!
 Post subject: Check again
PostPosted: Tue Jul 05, 2011 4:57 pm
I'm thinking you may have misread.
I read "Blue: 1970-1983 all passenger cars & trucks, North American market"
PostPosted: Tue Jul 05, 2011 5:22 pm
our car is a stock 1968 Dodge Dart slant six...I bought a super six set up off a 1976 Volare today @ the pick and pay bone yard
Uploaded with ImageShack.us
slant six's RULE!
PostPosted: Tue Jul 05, 2011 5:36 pm
Correct engine color is red. If yours is another color, somebody either swapped engines or hit your engine with a can of paint of a non-original color.
PostPosted: Tue Jul 05, 2011 6:10 pm
the stamp ID numbers above #1 plug tube are
F225R 1028
anywho?
slant six's RULE!
PostPosted: Tue Jul 05, 2011 10:41 pm
F: 1970 model year
225: Engine displacement
R: Passenger car engine
1024: Not a 10-kiloday calendar date, because 1024 would be 21 May 1964 and that doesn't match up with the engine's casting number. Next most likely possibility is that the engine was built on October 24, 1969.
PostPosted: Tue Jul 05, 2011 11:29 pm
Dan- I have to correct one minor point on that list of engine colors. 1983 slant six powered trucks and vans had black engines. The original motor in my brother's 83 van was black, the original motor from sixshotvanner's 83 van was black, the hydraulic motor EricW and I installed his old Satellite came out of an 83 van and was black, and every 83 Dodge van powered by a slant I have found in a junkyard has had a black slant six motor. The odd thing is that the 318 in my current 83 Dodge van is blue. Apparently slants were ahead of the curve in 83 when black became the motor color.
I can send you a picture of the factory black 83 slant block on the stand in my garage if you would like further confirmation.
PostPosted: Tue Jul 05, 2011 11:53 pm
No need for photos, looks like I was off by one year on the advent of black paint. I'll go edit the post -- thanks for the heads-up.
PostPosted: Wed Jul 06, 2011 1:08 am
I'm using duplicolor Chrysler industrial red, looks really good
PostPosted: Wed Jul 06, 2011 5:08 am
F: 1970 model year
SSD its
1028 on the block not 1024
slant six's RULE!
PostPosted: Wed Jul 06, 2011 6:35 am
The stock color on my '82 D150 slant was black as well, and I know the entire history of this truck so it's original.
1982 Dodge D150
Slant with a 727 Torqueflite.
PostPosted: Thu Jul 07, 2011 8:58 am
F: 1970 model year
SSD its
So is my engine a May 21, 1964 unit by the kiloday number ?
slant six's RULE!
PostPosted: Thu Jul 07, 2011 9:08 am
No. Re-read what I wrote.
Users browsing this forum: Bing [Bot] and 93 guests
