It is currently Mon Jun 22, 2026 4:36 pm
 Post subject: 7 1/4 axle strength
PostPosted: Tue Jul 19, 2011 4:15 pm
Is the 7 1/4 rear axle worth using for a t-bucket project?
I have a set of 3.55 gears for one and all new bearings brakes seals etc.
What will it handle horspower wise? should I leave the carrier open so it can spin freely instead of putting more stress on it using a posi traction setup. I have a 225 with nitrided crank, medium Isky cam, four barrel, four speed, msd multispark.
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Tue Jul 19, 2011 4:48 pm
Gulp... you said the "F" word... Four speed trans.
Dump the 7 1/4 and find something bigger.
If you really want to try it, put a clutch style limited slip into it, (if you can find one) doing that will make the unit a little stronger.
PostPosted: Wed Jul 20, 2011 9:44 am
Agree with Doc. Don't try a 7 1/4 without a clutch type suregrip (4 spider gears). I would also stay away from the 7 1/4 with a stick.
I am running a 3.91 7 1/4 SG in a 13 sec drag car, but it is an auto trans and doesn't "shock" the rear.
PostPosted: Wed Jul 20, 2011 3:19 pm
Cool thank you, Jon.
PostPosted: Thu Jul 21, 2011 3:19 pm
I have a Dana 60 with 4.11 gearset, if I made a spline adapter and welded the tubes on from the 7 1/4, do you suppose the axle shafts would hang in there.
I came up with the idea because the Dana is a full floater from a 73 POWER WAGON and I have all new parts for the 7 1/4
