It is currently Thu Jul 16, 2026 11:32 am
PostPosted: Sat Aug 20, 2011 7:35 pm
I was wondering if a piston is available that would fit this scenario.
225 block, 198 rods, 170 crank, Hooker 6 into 1 header and a turbo with a 3" exhaust side.
Looking for about 6 to 1 compression.
I have a stock 225 deck height of .074
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Sat Aug 20, 2011 8:02 pm
I dont think the 170 crank will fit in the 225 block. Also I dont think hooker makes a six into one,you would be better off building a custom turbo header.
PostPosted: Sun Aug 21, 2011 8:25 am
6:1 compression would be a dog off boost.
kev
PostPosted: Sun Aug 21, 2011 9:25 am
Points taken, I have a Hooker 6 into 1, also have a Comp Cams grind #268-10 for a slant (which Comp doesnt have specs for), brought the cam card to work to research and someone threw it any, its new in the box.
See my last couple posts under Duel fire inline six - on overcarbing the engine.
Thank yous.
 Post subject: ???
PostPosted: Sun Aug 21, 2011 11:39 am
That's because the code is incomplete...
A Comp slant six bump stick will have this format 64-LOBE-5, (lobe is a 4 digit code from their lobe library).
If it was from summit or a performance catalog then it would have this format CCA-264-1...but they would still need to know the lobe code
(64-6038-5)
PostPosted: Sun Aug 21, 2011 1:46 pm
170 crank will fit in a 225 block, there are no rods long enough to get the pistons far enough up the hole to get any compression. You would need close to an 8" rod. :shock:
PostPosted: Sun Aug 21, 2011 5:19 pm
I e mailed Comp Cams with what was on the box, 64-248-4 and grind # cr6 268h-10 s.n. T5070, it says CHRY 6 cyl on box too, the guy went to record files and no luck.
I realise now that the stock slant six blocks, with other stock components, have to much compression height to be a CART engine.
Thanks, I know what I can look at for a project now.
PostPosted: Sun Aug 21, 2011 5:54 pm
I guess you don't mean this kind of mopar powered CART...
Olaf. 8)
Aspenized
PostPosted: Wed Aug 24, 2011 8:54 pm
8 inche rod is not a problem,,,where to put it is.Guzzi Mark
