It is currently Fri Jun 05, 2026 12:01 pm
 Post subject: oil pressure tick
PostPosted: Sat Oct 08, 2011 11:58 am
so i was driving around the other day and i noticed that my oil pressure gauge was bouncing around at cruize... BTW its not constant... just here and there for a couple seconds at a time...
normally its steady @ 65-70psi and it was going as low as 30psi... it seemed to stop doing it under accel and did it a little under decel...
i know i'll get kicked for this but i am running a electric oil pressure gauge (before i new they wern't good lol) so im looking to order a mech one... Autometer Cobalt series...
so it has a deep pan with 6qts so i know its not low oil... today was gonna pull the dizzy and take a peak at the oil pump gear... (used an known old one...). also has a hemi spring in it.
any idea's?
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sat Oct 08, 2011 12:33 pm
ok so i went and had a look around..
the sending unit wire had come loose! so crisis averted...
PostPosted: Sat Oct 08, 2011 1:39 pm
You're lucky it wasn't an oil pipe to your mech gauge that came loose... :lol:
Olaf.
Aspenized
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
