It is currently Sun Jun 07, 2026 11:12 pm
PostPosted: Wed Dec 28, 2011 7:30 pm
im wondering what all i should be doing to my rebuilt motor on the stand, then what do i finish up when i drop it in.
meaning, is it easier to assemble manifolds on stand, or after its dropped in the car, certain brackets, coil, alternator, whatever whatever..
anything i should address on the car before slinging the motor?
it would be a great help if i could get a list of what makes the process easier, thanks guys
PostPosted: Wed Dec 28, 2011 8:00 pm
6 Pack Dart
Point of safety do not use a 3 leg engine stand, the slant engine will tip them over very easy.
Richard
PostPosted: Wed Dec 28, 2011 8:02 pm
i own a 4 wheel snap on engine stand, well blue point actually
 Post subject: If...
PostPosted: Wed Dec 28, 2011 8:21 pm
If you have shorty manifolds you can assemble the whole smash and prep it to drop into the car. I mount the alternator brackets, but do not install the alternator in case the engine needs to shift or be 'rocked' into place. You can also install your motor mounts as well (make sure the passenger side bracket is installed correctly).
PostPosted: Wed Dec 28, 2011 8:25 pm
do i install the actually mount on the motor, or only the brackets, and leave the rubber on the car?
 Post subject: Sandwich or spool
PostPosted: Wed Dec 28, 2011 8:30 pm
If it's spool that mount and drop it in. It sounds like you have sandwiches so I'd mount the brackets and leave the rubber in the car (although in my '67 Valiant I opted to mount the rubber on the passenger side then drop it in because that side is kind of tight to get a wrench into).
PostPosted: Wed Dec 28, 2011 8:38 pm
i have a 65 valiant. is there anything i should address in the car, before dropping it in? im getting a little ahead of my self, i still need to find an exhaust manifold, im probably going the dutra dual setup, but doc is out. i still need to order mounts, and i also need to figure out all the manifold hardware
PostPosted: Thu Dec 29, 2011 5:36 am
Now might be a good time to clean and paint the engine bay. Dehorn any sharp edges while you're at it.
PostPosted: Thu Dec 29, 2011 5:47 am
yup, while you are at it brush the rust away from the bay. 8)
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Thu Dec 29, 2011 11:17 am
The engine bay still has the original paint, no rust, unless your talking about the corners of the fenders and underneath the windshield. It's a given to degrees the whole frame, cross member, suspension and steering parts. Very dirty, just wondering if there is something out of the ordinary to address.
Also I can't remember what its for, its a bracket that's sort of triangle shaped, with a small 90* bend, with a hole at the tip, 2 more on the bend
PostPosted: Thu Dec 29, 2011 11:28 am
Car Model: '23 T-bucket
Sounds like the trans-to-engine bracket. Bolts on, under the starter, along side the oil pan. Single hole forward, with the two-hole flange matching up to the bell housing/starter bolts.
Roger
PostPosted: Thu Dec 29, 2011 11:29 am
PostPosted: Thu Dec 29, 2011 11:44 am
engine to trans bracket bolts under starter and to engine.....pressurewash under hood ,paint any rust
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
