It is currently Wed Dec 31, 2025 8:55 am
PostPosted: Fri Mar 09, 2012 9:29 pm
To Josh and others who have made adapters to mate a small input bearing retainer trans to an OD bell. How do you secure the adapter ring, and keep it from falling out into the bellhousing? I am considering going down this road, and am having a little trouble on this detail. Thanks in advance.
PostPosted: Fri Mar 09, 2012 9:49 pm
My adapter ring was an interference fit on the input bearing retainer.
PostPosted: Fri Mar 09, 2012 9:54 pm
Okay, thanks. That was the best option in my head, but wanted to check with someone outside my head, er, that had actually made/used one.
PostPosted: Sat Mar 10, 2012 3:18 pm
I remembered this morning that an adapter came with a BB Lakewood bellhousing that I have, so I dug it out! Alas, it is 4.35" i.d., and 4.80" o.d., not all the way to 5.125"...phooey. Guess I'll have to look up a machine shop on Monday.
PostPosted: Sat Mar 10, 2012 7:59 pm
What's your time frame for this? You might try the local Community College machining program.
PostPosted: Sat Mar 10, 2012 10:45 pm
haha I was just going to slap in a non-od box I have laying around, so I could still drive the car while I rebuild the stock OD unit (with 260k on it). However, I may just have to pretend this never happened...
Thanks for the idea, though!
