It is currently Sat Nov 21, 2026 9:38 am
PostPosted: Tue Apr 24, 2012 6:18 pm
10 years back (Mar 2002) DD provided an oil pan comparision and the following:
"FYI, the only other pan that will fit is the "369", mid 70s A & F body unit, the blue one in this pic. The front left corner of that pan comes close to the 60-66 K-frame so I dent it in a little to make clearance. (see the black lines)
DD "
The photo was:
https://picasaweb.google.com/1079134575 ... 5631551730
I've tried to locate the "black lines" to understand how to modify the 369 pan to fit my 65 Dart so I don't have to repeatly install the engine to verify clearance to the "K" member.
Has anyone got a clear picture showing the required modification?
PostPosted: Tue Apr 24, 2012 6:28 pm
Yeah those pics do leave some to be desired....
MRO....
PostPosted: Wed Apr 25, 2012 1:50 am
Same pic,but smaller. Might help/might not. Best one I have.
regards,Rod :D
PostPosted: Wed Apr 25, 2012 9:14 am
Errr... like these photos?
The "flat" steering center link on the 60-66 A-body vehicles is hard to clear with the 369 pan... the V - 8 centerlink give you a lot more clearance. (the rear "dented" area in the photos below)
img]http://www.dutra.org/dutraorg/pictures/engine/parts/369pan2.jpg[/img]
PostPosted: Wed Apr 25, 2012 9:34 am
Those pictures are perfect....thank you DD.
Can I modify a 69 oil pickup to fit the modified 369 pan (out of a 75 Dart) since I'm mounting the 369 oil pan to a 69 motor or is it possible the pickup will fit without modification?
PostPosted: Wed Apr 25, 2012 11:25 am
If the pick-up tube is in the center of the sump and with-in a 1/4 to the floor of the pan, you are "good to go".
Dab some grease on the pick-up's edge and set the pan on, with-out the gasket, to get a mark on where the pick-up is locating, with-in the pan.
PostPosted: Wed Apr 25, 2012 6:33 pm
The DD middle picture of the orange pan appears to be correctly oriented considering drain plug orientation and location/orientation of "369".
The top picture looks "inside out"...in drafting this would be called "symmetric about centerline whereby the top picture would be one side of the centerline of a pair of pans and the middle picture would be the other side of the centerline............is this some strange photo software technique?
PostPosted: Thu Apr 26, 2012 9:26 am
Good eye...
Looks like I scanned a negitive "up-side-down"... :oops: :(
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 6 guests
