It is currently Tue Oct 13, 2026 11:54 pm
 Post subject: 7.25 axle lube
PostPosted: Mon Apr 30, 2012 10:42 am
Car Model: 1964 Dart 270
What is the recommended axle lube for a 64 7.25 rear axle?
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Mon Apr 30, 2012 10:57 am
Used to be SAE90 unless it is really cold out, but a 75W-90 or 80W-90 GL5 is the modern choice.
 Post subject: Axle Lube
PostPosted: Mon Apr 30, 2012 11:02 am
Thanks Joshua the Motors Repair Manual tells how much but not what weight to use.
