It is currently Thu Nov 26, 2026 3:15 am
 Post subject: mopar mini starters?
PostPosted: Wed May 16, 2012 1:12 pm
so whats a good price for a rebuilt one..I think of trying one.
slant six's RULE!
http://www.usajon.com
PostPosted: Wed May 16, 2012 2:04 pm
Try rockauto.com I don't think they ever were higher then any place local. Although, quality wise you're probably better off getting an original used one from a wrecking yard. The only thing that typically goes wrong with them are the solenoid contacts that wear and those are available - Dan had a post that detailed the numbers and pictures.
 Post subject: well
PostPosted: Wed May 16, 2012 2:37 pm
do you think a rebuilt in USA unit is OK
see this item
http://www.ebay.com/itm/MOPAR-MINI-STAR ... es&vxp=mtr
slant six's RULE!
PostPosted: Wed May 16, 2012 6:16 pm
That's what I put on my valiant.
Rick
PostPosted: Wed May 16, 2012 6:48 pm
Wayne drug one up from a junkyard for the red car. IIRC he gave like $20 for it. :shock:
PostPosted: Wed May 16, 2012 9:55 pm
The black part of the housing just doesn't look right... For the price its going for you really otta look at a local yard, they should be plentiful.
 Post subject: how bout this unit
PostPosted: Fri May 18, 2012 9:09 pm
is this unit OK
http://www.ebay.com/itm/NEW-MINI-MOPAR- ... 2242451073
slant six's RULE!
PostPosted: Thu May 24, 2012 9:37 pm
I bought one at the wrecking yard for 35. It turned out to be a very recent genuine chrysler rebuilt unit.
Works great. It cranks much stronger than the original (faster), and is nowhere near as loud.
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Thu May 24, 2012 11:00 pm
The parts to rebuilt it are like 12 bucks, and take 5 minutes. Save your money and have an excuse to go to the wrecking yard. Win-win!
