It is currently Sun Nov 15, 2026 6:59 pm
 Post subject: 2nd gear slipping on 904
PostPosted: Mon Sep 03, 2012 2:12 pm
Tried some lucas but didnt help. The new motor l believe has taken a toll on the old girl ?[/b]
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Mon Sep 03, 2012 2:36 pm
Not surprising.
Here is a useful diagnostic aid:
This tells you what components are in use during each gear. You can use this to test which gears have difficulty and almost pinpoint what components of the transmission are faulty.
Second gear uses the rear clutch and the front band. First and third gear also use the rear clutch. If first and third are OK, then I would suspect the front band.
PostPosted: Mon Sep 03, 2012 5:37 pm
Thanks Reed thought maybe I would have to rebuild so will go with that for know.
PostPosted: Mon Sep 03, 2012 6:31 pm
You might try a band adjustment first.
PostPosted: Mon Sep 03, 2012 8:28 pm
Will try thanks
PostPosted: Wed Sep 05, 2012 4:39 pm
Is the throttle pressure linkage adjusted correctly?
