It is currently Wed Jun 10, 2026 9:46 pm
PostPosted: Sat Apr 27, 2013 8:22 am
when i turn the head lights on my fender mounted turn signals come on are they supposed to do this it truthfully baffles me and my dad had a scamp with the light package years ago and i cant remember if they come on :?
trying to keep it low key here in my Valiant200
PostPosted: Sat Apr 27, 2013 8:27 am
They are not supposed to come on with the headlights. Do your turn signals work? Have you double checked that you aren't using a single filament bulb in a socket intended for a dual filament bulb?
PostPosted: Sat Apr 27, 2013 8:32 am
i didnt think they were supposed to come on i have the correct amber bulbs in it with the dual filament and my turn signal do work but i do know the fender mounts are the 73 and up style i dont know if that would have any effect on the way they work :shrug:
PostPosted: Sat Apr 27, 2013 8:46 am
i forgot to mention that when the lights are off everything is normal even the signal work in unison as they should
PostPosted: Mon Apr 29, 2013 3:18 am
Check your PM's derrick
PostPosted: Mon Apr 29, 2013 8:07 pm
my light problem was a ground issue got it fixed
