It is currently Fri Nov 20, 2026 12:42 am
PostPosted: Tue Jun 25, 2013 5:56 pm
I am gathering materials and instructions on how to upgrade the 2.2 rear gears in the 8.25 rear axle in my brother's Duster to 3.2 rear gears out of a mid-70s Dodge van rear axle. I have the full carrier to go with the 3.2 gears due to the size difference in the 2.2 gear carrier and the lower ratio carriers.
Anyway, my question is about the special tool for the adjusters in the rear axle. I have read that a 1 1/4 inch nut welded onto some all-thread will work, but I have also heard that old A-body torsion bars also work. Is that true?
Thanks!
PostPosted: Tue Jun 25, 2013 6:10 pm
"A" body bars are too small for the adjuster on a 7 1/4 rear. I think it is either "B" or "C" body bars.
PostPosted: Tue Jun 25, 2013 6:20 pm
Did you mean 7 1/4 or 8 1/4 rear axle? I will guess you meant 8 1/4 since I will assume the adjusters on the 8 1/4 are bigger than the 7 1/4 and if the A-body torsion bars worked on any axle it would be the smallest (the 7 1/4). Looks like it is time to break down and buy the tool or make one out of a nut and some all-thread.
PostPosted: Tue Jun 25, 2013 8:47 pm
you are looking for a c body tortion bar to use for the adjuster not an abody
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
PostPosted: Tue Jun 25, 2013 9:42 pm
Got it. Looks like I will be tracking down the correct tool. Thanks for the input guys.
PostPosted: Wed Jun 26, 2013 5:00 am
I meant the 7 1/4. I have never done a 8 1/4, and was assuming if the "A" body bars were too small for the 7 1/4, they would be too small for the 8 1/4 also. Actually what I did was use a broken "A" body bar, and weld a nut to that. I would have to measure the size of the nut, as at my age I have CRS.
PostPosted: Wed Jun 26, 2013 10:59 am
I think both axles use the same size adjuster/tool.
I made a tool using a common 36mm (about 1 7/16") hex axle nut (Honda, etc.) that you should be able to find used laying around any mechanic shop.
I had a piece of aluminum curtain/shower rod that fit nicely inside it, so I used the stake flange of the nut to lock them together.
Works beautifully.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Mon Jul 08, 2013 5:32 pm
YOu can also use an F-J-M curved bar for this job.
Cut the Hex off of it and weld it to a straight shaft.
it is the correct size as I have done this.
