It is currently Mon Oct 26, 2026 9:28 am
PostPosted: Fri Mar 21, 2003 12:32 pm
Dist. is back in everything seems right there. But now I am not getting spark from the coil. Would the coil be the likely culprit or that other electric thing????
PostPosted: Fri Mar 28, 2003 7:02 am
If you have an electronic ignition, it could be the white ballast resistor. It acts like a dead coil.
PostPosted: Fri Mar 28, 2003 10:26 am
also if electronic, check the magnetic pickup gap in the dist with a brss feeler gauge. Should be .008". If the gap is too large--no spark (ask how i know :roll: )
-Aaron
The "Silver Bullet"
87 Ram D150
 Post subject: no spark
PostPosted: Fri Mar 28, 2003 12:04 pm
Or the module itself if electronic
PostPosted: Fri Mar 28, 2003 5:01 pm
Got it going!!!
Now i just have to get the old gas out of it.
Thanks for the help on all the dumb questions.
Brett A. Snell
1947 Ford Biz Coupe (disassembled)
1961 Nash Metropolitian
1968 Dodge Dart
1993 Mercedes Benz 500 SEL
PostPosted: Sun Mar 30, 2003 10:45 pm
Xsnail,
What did you have to do to get it going?
Just wondering in case I have the same problem later.
Jerry
PostPosted: Mon Mar 31, 2003 5:45 pm
Ugg. do I have too? It was kind of dumb.
The fusable link had burned. But it did not totaly separate or noticeably go bad. When I touched it the insulation came off very easily with only a few strands of wire still intact.
