It is currently Thu Nov 12, 2026 6:57 pm
PostPosted: Sun Nov 02, 2014 5:29 pm
anyone know this.
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Nov 02, 2014 9:14 pm
Super Stock 426 Hemi 1968 Plymouth Barracuda and Dodge Dart
PostPosted: Mon Nov 03, 2014 6:33 am
From 1966 on the Dana 60 was standard on stick 426 and many 440 B and E bodies, it might have also been an option with automatics on those cars. There was another little used Dana with a 9 1/4 ring gear for 440 stick C bodies.
PostPosted: Mon Nov 03, 2014 8:34 am
Stick only, auto cars came with 8-3/4 rears. Danas were B body units, hence the odd cut wheel openings on Darts.
So the correct answer is there was never was an A body width Dana 60 from Ma Mopar.
PostPosted: Mon Nov 03, 2014 1:38 pm
There are a lot better ways to put power to the ground . They are pig heavy and no fun to work on.
If you have a 5000 lb 2000hp pulling truck just maybe its better than a good 9" Ford.....but then you have the case that the truck weighs 5000lbs cuz you use stupid heavy stuff.....
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 2 guests
