It is currently Fri Nov 20, 2026 4:11 am
 Post subject: Oil Leak
PostPosted: Sat Aug 01, 2015 8:17 pm
Car Model: 1961 Dodge D100
I installed a new oil pump today in a '61 Dodge D100. Pretty easy and straightforward - there's a lot of room to maneuver in the trucks. The new pump is a Sealed Power 224-4165C, a regular old pump. And it leaks.
When I pulled the old pump, I cleaned thoroughly around the area - it was pretty gunky, to the tune of 1/8" to 1/4" of 54 year old sludge. I used the gasket that came with the new pump.
It's leaking right where bolt #6 would be if it weren't a 5 bolt pump. I was able to slow the leak down quite a bit by pretty severely tightening down the bolts on either side of the "missing" bolt. But it still leaks about a drop every second at idle when I first start it up. I haven't let it run to get warm. Pressure is about 40psi at idle, 55 when I rev it up.
I'm using 5w30 oil and a Wix 51806 filter (previously it used the replaceable element filter). I'm not sure how to proceed here - double up the gasket? Use some kind of sealer?
PostPosted: Sat Aug 01, 2015 9:33 pm
Car Model: 62 Valiant
i would try replacing the gasket and using silicone on both sides of it, also make sure the surfaces are clean and straight, no gunk or ncks or warpage
PostPosted: Sun Aug 02, 2015 3:30 am
look at the picture in this thread.
http://slantsix.org/forum/viewtopic.php ... ump#371660
PostPosted: Mon Aug 03, 2015 6:06 am
It was the right gasket. I replaced it with a new one, though, and used a little bit of Permatex RTV. It doesn't leak now.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 6 guests
