It is currently Sat Nov 14, 2026 3:52 am
PostPosted: Sun Aug 09, 2015 4:03 pm
few weeks ago i mount the slanty in the car. Then i connect every thing... then i start the engine after some distributor turns... and voila... the slant rebuilt by my hands was running after some 4 years (this is an extralarge history) and i turn off to regulate valves and put the valve cover... when i want to start again... cri cri... cri crikets.... nothing happens... take a spark plug and no spark is in.... i buy a new ignition coil a new ballast resistor new wires... and nothing... then i change the electronic ignition module... and today start again... but run 1.... run 2... run 3 times... but at the 4 th start dont have spark again... and i think something is blowing the electronic ignition module... someone had an idea or wathever... thanks from Chile
dodge aspen 79 AT
PostPosted: Mon Aug 31, 2015 11:29 am
Thanks guys. The fail was on the pickup coil and reluctor had some scratches. I clean all... give a ,008" gap beetween reluctor and pickup and the slanty start at the key. Ralenti is ok and now i will shot the estrboscopic light to find the time. Thanks again.
Read you later.
dodge aspen 79 AT
