It is currently Fri Jul 17, 2026 4:14 pm
 Post subject: Engine run stand
PostPosted: Wed Sep 14, 2016 8:08 pm
Who has built one specifically for a slant? I have a rough idea of how I want to do it but maybe someone has something better than what I have in my head. Lets see some pictures...
 Post subject: Lol...
PostPosted: Wed Sep 14, 2016 9:12 pm
I have one, that I need to get my shop cleaned up so I can dig is back out and use it....
I worked with my buddy to build it, so it's like a 4 wheeled cart with "locking wheels", but made the side rails "universal" to bolt up any 1967-1976 A body K-member... so I can bolt in a /6 or LA 'K' and test which ever engine I need to work on. The rear mount is set for a 4 speed bellhousing bolt pattern, that way I can use a standard bell and flywheel to mount a starter...
I have an upright to mount the EI ignition system to it, and the "pushbar" part of the cart has a wide metal 'C' channel I can mount gauges to (in between the uprights it's wide enough to mount an A-body radiator the correct dimension to use stock late A-body hoses... (there is also a battery tray on the side and I figured on using a marine gas tank to hook to the fuel pump for carb'd motors (EFI testing will need a bit more "stuff")
If I get time to dig it out I will take pics of it for you.
PostPosted: Wed Sep 14, 2016 9:52 pm
I was thinking about making it for slants only seeing as how I have 5 or 6 of them laying around. I have a 73 A-body radiator, spare 73 and up spool mounts, spare electric fan, battery box, I would run a boat tank unless I come across a small Moon Equip. style tank, have gauges/throttle cable permanently mounted along with an HEI unit unless I am running a magneto or points.
Defiantly locking casters and make it as compact as possible. I just need to drag one of the engines to work so I can start laying it out.
Always looking for rare slant speed parts and slant Hilborn stuff.
WANTED...Wilford Days Slant coffee table (yes that one). Last known owner was Mr. Stepp. Any leads appreciated.
Looking for any old Dragmaster Dart Six stuff.
PostPosted: Thu Sep 15, 2016 7:28 am
Long time ago I parted out a 66 Barracuda and saved the core support, front rails, K Frame and transmission crossmember as one unit. I made a set of wheeled mounts that bolt to the front and rear. Since the K is the same for a slant and V8, using the proper motor mounts will allow me to break in either a slant or V8. Since it's all basically open, there's plenty of room to keep and eye on everything.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Thu Sep 15, 2016 8:20 am
I have an extra late a bdy slant K frame, but I have also considered building one from scratch. However, a realy cool option for a slant only stand would be the housing from a slant powered stationary power unit like a generator, sawmill, or water pump. A factory Chrysler engine run-in stand with all thegauges, radiator, and ignition system would be pretty nifty.
PostPosted: Thu Oct 13, 2016 9:34 am
WOW! What kind of wheels are you using to support the K member?
Thats beefy! PLUS the engine...wow!
PostPosted: Thu Oct 13, 2016 12:29 pm
Actually, the basic core support, frame rails and transmission cross member aren't that heavy. Add the K Frame, radiator and motor/ftransmission - now there's a little weight. There are no inner fenders or firewall. I used 2x2 boxed tubing, a section of a pair of bumper brackets and some 6 inch swivel wheels up front and a pair of wheel assemblies from the tongue of a trailer on the rear. All the wheels are removable so the stand can be stood on the core support end; works great!!
PostPosted: Thu Oct 20, 2016 11:29 am
Car Model: 62 Valiant and 62 Lancer, both Swiss Made
Here's my simple stand:
https://youtu.be/FdhoWAEHJjw
Philipp
62 Valiant
62 Lancer
Users browsing this forum: No registered users and 29 guests
