It is currently Sat Nov 21, 2026 2:37 am
 Post subject: Power steering question
PostPosted: Thu Feb 02, 2017 4:45 pm
Car Model: 1968 Plymouth Barracuda slant 6 super six 4 speed.
Hey guys, got a question about power steering and would like to be educated, will a car power steering pump off an early a body work and operate on a slant 6 truck? Thanks :)
I'm human and I do things for the universe.
PostPosted: Fri Feb 03, 2017 4:24 pm
What year truck? Why not rebuild or buy a new pump from thru parts store? There are a few different types of pumps and different hose types. Some depend on year as well.
I'm going to attempt to fix this project and not make it any worse.
PostPosted: Fri Feb 03, 2017 6:00 pm
It's a 75 dodge w100, has power steering gear box from factory. I'm converting the truck to a turbo slant 6 and would like to keep power steering. The slant 6 power steering pump, brackets, and pulley was given to me by a friend.
PostPosted: Fri Feb 03, 2017 8:07 pm
No reason why it won't work if it will bolt up. I think the 75 box uses o-ring hose and the early pumps are flare. Hoses will probably be the issue. I have the similar issue...73 pump on a new CPP gear box.
