It is currently Fri Jul 17, 2026 8:16 am
 Post subject: Check your pinion nut
PostPosted: Mon Aug 18, 2003 10:28 am
Discovered my pinion nut to be only finger tight, so Check them for proper tourque, mind you it took 40 years to loosen as has never been apart, but now have possible reason for pinion bearing failure and constant u-joint failures . One more use for locktite.....Dave
PostPosted: Mon Aug 18, 2003 10:59 am
If the pinion used left hand threads there would not be problems like this.
Cecil
