It is currently Sun Jun 14, 2026 7:04 pm
PostPosted: Wed Jan 14, 2026 1:24 pm
I removed the flywheel from my 76 225 Dart Sport.
There is a huge inertia ring cast into the back of the flywheel.
122 tooth flywheel with standard clutch pattern, around 10 inches.
Starter teeth are pretty chewed up, so I was going to swap with a better wheel I have.
What is the deal with the big ring flywheel?
PostPosted: Thu Jan 15, 2026 2:03 am
You used to be able to get just the starter ring and press on a new one. Not sure if they are still available. All cast cranks, AFAIK, are all neutral balance just like the forged ones, so flywheels interchange. Maybe they wanted to put extra mass on because the crank got lighter? I have an alum flywheel on my high RPM cast crank (ltwt 62 lb) motor and it feels great. You notice it won't drive off as smoothly as a heavy crank and 'wheel, but no biggie. Engine is smooth as silk, vibration-wise.
Usually the 225 stock iron flywheels are around 20-22 lbs. I think I've seen 1-2 that were more like 28-30 lbs, but I'm not sure I'm remembering correctly. Maybe those were the big ones for 11" clutch. Aftermarket standard size aluminum flywheels are 10-12 lbs.
PostPosted: Thu Jan 15, 2026 9:25 am
Hmm. Please post a picture of that stan, I have not seen one.
Maybe Rick can offer some insight with all of those 80's trucks he has cared for over the years.
PostPosted: Thu Jan 15, 2026 12:48 pm
Online
Probably exactly what you said. Inertia ring probably is to get that low horsepower , heavy car, with way too high of gears moving. Post a pic :D
PostPosted: Thu Jan 15, 2026 2:44 pm
Low Horsepower, maybe.....
Heavy Car, "It's a Lite" for crying out loud!
High Gear, 1st is a 3.09 for crying out loud!
PostPosted: Thu Jan 15, 2026 4:01 pm
Huh
I have 2 flywheels off of 80s trucks with the/6 and neither one has that
PostPosted: Thu Jan 15, 2026 4:56 pm
I have never seen one like that.
Post the part # and let's see what SlantSixDan can teach us about the part!
My 79 Aspen cast crank 3 speed had a regular flywheel.
Your 2.76/ 2.71 with the 3.09 is still only an 8.52:1 / 8.37:1 ish gear depending on tire size.
Cool parts to find about.
PostPosted: Thu Jan 15, 2026 5:41 pm
Never seen one like that! Please post a weight when you get a chance.
PostPosted: Fri Jan 16, 2026 5:42 am
Online
I just make stuff up as I go Stan! :D They may have just had a bunch of forklift stuff laying around to get rid of! :D
PostPosted: Fri Jan 16, 2026 9:23 am
28 Lbs 3878965
VS
23 Lbs. 122 Tooth Flywheel, no inertial ring. 2128290
Ring Cast Number.
PostPosted: Fri Jan 16, 2026 9:45 am
Online
It also looks like that ring would be pretty close to the back of the block.
PostPosted: Fri Jan 16, 2026 9:51 am
Thanks Stan!
PostPosted: Fri Jan 16, 2026 10:29 am
It was on the engine, so it fits.
PostPosted: Fri Jan 16, 2026 11:39 pm
Stan, that appears to be offset back, like it's for the bellhousing adapter stuff of the '70's....without using a spacer.
PostPosted: Sat Jan 17, 2026 7:08 am
[/quote]
You make stuff up?!?!?!
