It is currently Sat Oct 17, 2026 9:15 pm
PostPosted: Mon Nov 10, 2025 7:04 pm
If anyone else is crazy enough to care or wants to buy a light flywheel made for the Stock Slant 6 bell housings in the 122 Tooth ring gear configuration, I was able to get in contact with RAM Clutches to get 3 of these made for myself.
They have my order# on file and the appropriate CAD and CAM files to make more for you if you wish.
At the time of purchase ~3 weeks ago in October 2025, They charged me $650 per flywheel which I feel is appropriate. Their raw material costs are rising and they honored the quoted price that we discussed in back in ~August 2025. Very kind on their part.
I was able to get in touch with Mike over the summer at RAM.
It took a while but I was able to get 3 of the Semi-Custom Slant 6 Billet AL Flywheels produced for my Slant 6 Road Racing Setups and or Future projects.
We owe a big thank you to Dan Brewer of Brewers Performance as well. He has RAM Clutches Stocking stock type billet steel 122T slant 6 flywheels and he gave me direct contact Info for Mike to get this project started.
The Aluminum parts I share here are not stocking part#'s but can be made on a to be ordered basis.
Specifications and Pictures below:
*122 Tooth
*Fits in Stock Slant 6 Bell Housings Such as:
**3 Speed AL
**4 Speed '64-'66 Cast Iron
**4 Speed 833 OD Multi-pattern 1975-87 AL.
* Large Bore Crank Pocket (easily adapted to 1960-1967 Cranks with an annular adapter that I have made here locally).
* Weighs 10.1 - 10.09#
* Can Accept a Ø9.25" to 10" clutch disc
* RAM has my Order # if anyone else would be interested and willing to shell out the ca$h. They can make these with 3 Pressure plate patterns:
* I had 3 flywheels made in different configurations. Can be made with 2 patterns on a single flywheel.
* Available Pressure Plate Bolt Patterns:
**Stock Borg and Beck Slant 6 9.25" / 10"
**Ford / Mazda 10" Diaphragm (2001-2011 For d Ranger with 4.0 V6)
**RAM 9.5" Pressure Plate
Some Pictures:
PostPosted: Tue Nov 11, 2025 5:49 am
How does the weight compare to the original units? I am going the T5 route in the future so being able to buy a new LIGHT flywheel that already has the ford PP pattern would save on machine shop time.
PostPosted: Tue Nov 11, 2025 6:23 am
I have yet to weigh an OE part, but I have them available for such comparisons.
Give me a minute to get that for ya.
They are heavy, I can assure you, and the Flywheel is an angular momentum part. So someone smarter than me can better explain the physics of it all. For a svelte street car or a road racer, you want the ability to blip the throttle and not need to spin up / change the inertia of a big, heavy thing. We already have that in the stock ~75 # crankshaft.
PostPosted: Tue Nov 11, 2025 7:54 am
I remember years ago when I played around with the old 2.2 turbo cars that the aluminum flywheel was suggested as one of the best upgrades you could get for a build. My valiant (65 2drht) is likely pretty close in weight to a full option G-body daytona. I would eventually like to build a high rev turbo 170 for the car, but I am sure the 225 would appreciate the lighter flywheel as well.
My memory is that the heavy flywheel is to help get a large heavy car moving from a stop. My car isn't heavy and the gearing that will come with the T5 swap makes that even less of an issue.
Kinda makes me curious about how well the OE flywheels were actually balanced when produced. Chrysler had some questionable quality control and machining tolerances and something that heavy could certainly be out of balance.
PostPosted: Tue Nov 11, 2025 9:33 am
My all steel racing flywheel weighs only 16.5# and that is for a 10.5" clutch. I thought I remembered that the factory flywheels were 28-30#?? (I was only off by about 10#!) Yours look sweet and should rev quickly! :D
PostPosted: Tue Nov 11, 2025 9:53 am
Stock slant 6 iron flywheel is right around 20#. The lightest aluninum flywheel I've seen for a Slant is just under 10# and the wilcap ones are like 10-11#. These look like beautiful units, Greg, and at a very fair price. This is a fair bit of work, and I really appreciate it!
I plan to order 1-2 of them, likely with the 9.5" PP and whatever disc looks best.
Thanks a ton!
PostPosted: Wed Nov 12, 2025 5:00 pm
Weight comparison of a 2128290 stock large crank pocket 122T Flywheel:
And a second one: - same P/N; different supplier.
PostPosted: Tue Jan 27, 2026 12:27 pm
Continuing my flywheel clutch issues.
Now that I know my "cast" crank engine is a forged crank I have moved to clutch issues.
I never had any luck with the 9.5 Borg and Beck pressure plates in my street cars.
Years ago I would buy the 10 inch PP that was listed for trucks.
These are the scalloped covers to use all the flywheel out to the mounting bolts.
That is what is in the Dart now, although it is quite used and of unknown condition.
I spoke to "Joe" at H.R. Clutches and he can build a hybrid clutch from my old cover.
Add 3 springs to make 12 and use high quality spring material for better heat performance.
They are in Bensalem PA.
Are there other solutions for the B&B clutch route?
I have an old WEBER pressure plate (9.5 inch) here but was warned the spring/pedal pressure is "HIGH".
PostPosted: Tue Jan 27, 2026 2:27 pm
Stan at our advanced ages, I would not want something that pushes all that hard. I would go with a modern diaphram unit with a good dual friction disc. Was Ram making a bolt in pressure plate for the Slant 6 pattern? I can't remember.
PostPosted: Tue Jan 27, 2026 2:46 pm
I don't know, maybe Greg does.
What clutch are you planning?
PostPosted: Tue Jan 27, 2026 3:12 pm
This is the Brewers package.
Must be used with their flywheel.
PostPosted: Tue Jan 27, 2026 5:43 pm
Must be used with their flywheel likely means it is not a Slant 6 pattern pressure plate.
I am using a 10 1/2" McLeod V8 Clutch & Pressure plate inside a Quicktime Slant 6 blow proof.
PostPosted: Wed Jan 28, 2026 7:17 am
I have an old WEBER pressure plate (9.5 inch) here, but was warned the spring/pedal pressure is "HIGH".
Hi Stan,
You can use the 10" Borg and Beck and have it rebuilt as needed by your guy or any other reputable clutch rebuilder, Falcon Clutches, Kentucky Clutch, South Bend Clutch, etc.
I would avoid the 10" for any performance use. In a stockish/driver setup, it will be fine, just avoid high RPM.
If you want to sell that Weber 9.5" unit, please contact me - I may be interested in it.
I have gotten to the phase of my clutch life where I buy the discs/plates / Flywheels I want from different suppliers and put my boutique stuff together. No one really makes a package that I usually want, because.... Slant 6.
You (or a reputable machinist more likely) can drill out your stock flywheel for any clutch cover/pressure plate you want. I have done that here to install a Ford Mazda 10" Diaphghram PP onto the flywheel for my '62 Vlaiant wagon. Works great, and I have towed ~2000# of trailer behind it with the stock/stupid/clunky 903 3 speed.
For the slant 6 stock B&B Bolt pattern, there are 3 options:
1. Stock 9.25" Cover
2. Stock 10" truck Cover
3. **Fiero diaphragm uses this bolt pattern as well** - I need to verify this for sure, but this is my assumption.
I have a smaller Spec ~9" clutch cover that is a diaphragm design (**assumed fiero bolt pattern for the clutch cover) that I have placed in my heavy Volare'-Duster f Body, and it works fine in that car. I bought this from someone who bought it new from the "spec group buy" 15+ years ago.
Some things to consider:
*The flywheel does not care what clutch cover is bolted to it.
*The clutch cover does not care what disc is driving the transmission, as long as it works and has the same spline count as the input shaft, and physically fits (within reason) under the clutch cover.
Happy to discuss further. Give me a call.
PostPosted: Wed Jan 28, 2026 7:18 am
Last thought:
If you want the whole deal to be idiot-proof, just buy the ram package.
It's good stuff!
PostPosted: Thu Jan 29, 2026 1:16 pm
Thanks for all the good info Greg.
At this point I don't have another thousand for a clutch flywheel in the budget.
Users browsing this forum: Bing [Bot] and 17 guests
