It is currently Fri Nov 27, 2026 12:17 am
Post new topic  Reply to topic  [ 67 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Dec 19, 2008 11:54 am
Ho-ho-ho! (had my first-ever request to play Santa at a Xmas party this year...)
So you finally found the big lights... playing the part of jolly old Slanta.
Heads up for yeah Slanta, you won't have to stop at my place this year, as I to have purchased a gift for the little women & my self, a Select Number Bed. Now, I hope to be dreaming in color of Mopars and slanty little engines, and not viewing cable infomercials all night any more.
PostPosted: Fri Dec 19, 2008 11:56 am
Dear Slanta Claus-
I want an aussie speed intake manifold and gasket set.
A shiney new carb.
And a set of dutra duals for Christmas.
Oh and world peace....But you could skip that last one as long as I get the Dutra Duals :twisted:
...and a partridge in a pear tree?
PostPosted: Fri Dec 19, 2008 12:01 pm
I thought it was a partridge cooked on a plate for me :?
PostPosted: Fri Dec 19, 2008 1:01 pm
No. "And a beeeeer in a tree."
vm
PostPosted: Fri Dec 19, 2008 1:09 pm
We sure are a social bunch here at the /6 forum... Way off topic :roll:
Chris'
Autobody
Restoration
Service
PostPosted: Fri Dec 19, 2008 9:10 pm
NAH - just a bunch of guys enjoying them selves we even have a Slanta Claus :D
Fess up Dan what is on the Christmas Dinner Menu :?:
BTW Josh thanks for the info on the retainers and CR - I wish cam manufacturers would go the extra mile and give one that info
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Fri Dec 19, 2008 10:41 pm
No problem. As most everyone here knows there aren't many people that work with these engines that are also employed by cam grinding companies. Comp gives suggested compression ratios for a lot of their cams along with other recommended equipment, but nothing for the slant.
I once tried a Crane Cams spring and retainer package they list for Chrysler small blocks. The retainer was kinda goofy and reduced the spring installed height by a bunch. Those things went back and I bought Comp springs and retainers which were made nicer and had a reasonable installed height.
PostPosted: Sat Dec 20, 2008 5:10 am
If you want a real treat call Comp and talk to Tim Cole. He is a six cylinder Comp racer and incredibly knowledgable about doing little motors like ours. :D
PostPosted: Sat Dec 20, 2008 6:19 am
the stock retainer work perfect, all you need are hardened locks that are with the engnbldr valves.
PostPosted: Sat Dec 20, 2008 10:01 am
Hi Terry - so the stock retainer is OK with 340 springs? Cool just saved me a bunch
Regards,
Fanie Gerber
PostPosted: Sat Dec 20, 2008 10:17 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Likewise. Really good to know!
Chuck and the Flying Valiant
PostPosted: Sat Dec 20, 2008 10:39 am
those comp units at 55usd ex shipping ouch :shock:
Regards,
Fanie Gerber
PostPosted: Sat Dec 20, 2008 11:25 am
Josh - the isky 264 - advance it slightly?
Regards,
Fanie Gerber
PostPosted: Sat Dec 20, 2008 2:52 pm
yes i have used them in all my engines with no problems,just spend your money on good harden locks,that is what will have the most pressure on them. i tried mopar`s aluminum retainer on one engine and never seen any gains.
PostPosted: Sat Dec 20, 2008 4:46 pm
Personally I would not use a stock spring retainer on a larger that stock diameter spring. Stock retainers (and locks) are fine for light loads and low engine speeds. With a heavier spring, more aggressive cam and higher speeds I do not trust stock retainers to stay in the spring without falling in or trust it not to split. A friend had to write off an entire engine due to a retainer failure. A set of good retainers is much cheaper than a new engine.
Users browsing this forum: Amazon [Bot], Google [Bot] and 20 guests
