It is currently Sun May 10, 2026 4:42 am
Post new topic  Reply to topic  [ 1340 posts ]  Go to page Previous 13 4 5 6 790 Next
 Post subject: Pan Progress 12-30-09
PostPosted: Wed Dec 30, 2009 8:04 pm
Online
Well The 4" Extension is finished as well as adding a baffle with trap doors to keep oil at the pickup on the hard launches.
The Trap Doors were made from simple 2" steel Hardware store hinges and A lot of layout and welding. Tomorrow's Tasks include putting a slosh Baffle in at the top of the pan and Making a Dipstick guide for the side of the pan.
Pics below of today's accomplishments.
Oil Pan comparison Shot - Stock A Body to Ruster's Oil Pan in progress
PostPosted: Wed Dec 30, 2009 8:10 pm
I don't understand what the baffle/hinges are doing, and the pictures aren't helping. All I see is a deeper pan.....
Got a hand-drawn picture of what supposed to happen?
PostPosted: Wed Dec 30, 2009 8:40 pm
Those trap doors look goofy to me too. Seems you will eliminate volume except under braking. 4" drop is a LOT. 2" is the most I've done. Springs on the trap doors?
Nice work on that stuff!
PostPosted: Thu Dec 31, 2009 5:47 am
Online
Well after studying other oil pan designs Moroso, Canton Etc. it seems the manufactuers use the oneway doors to keep oil near the pickup - On larger more elaborate pans they might have more than 2 doors.
So On a drag only car I feel that I just need one baffle / door set - It lets any of the oil into the area before (forward) of the baffle then Keeps the Pickup covered under acceleration rather then having all slosh to the rear of the pan.
We'll see how well it works - I can always take the baffle out if I dont like it.
PostPosted: Thu Dec 31, 2009 6:48 am
OK, sounds good.
PostPosted: Thu Dec 31, 2009 7:26 am
Only thing I would fear with a pan that deep is knocking it off on the return road, or under braking. :shock:
PostPosted: Thu Dec 31, 2009 9:19 am
Greg,
Might be a little deep. It would suck to take it apart once you got it into the car. Not sure if you recall my pan but I've banged it a few times. I believe it had 2.5" added to the center. I can put 7 quarts into the sump alone.
Additionally, I trimmed the trailing edge off and welded the edge of the k frame. It made taking the pan on/off a whole lot easier while the engine was in the car.
Tom
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Dec 31, 2009 9:58 am
Online
Thanks Tom and Dennis - I will look into these ideas when I get the Engine in the car - I am running large 15" front runners and I can always crank up the Torsion Bars too! Maybe I will put A skid plate on the K frame ahead of the pan? :lol: if needed.
PostPosted: Thu Dec 31, 2009 5:20 pm
Very nice work but I would bee afraid of 4 in,when your front end comes off the ground I would be afraid of smashing the pan when it comes back down.I also worked on my 2inch dropped pan today.I am on my second one.First one came out horrible.Guzzi mark
 Post subject: 1-2-10 More Pan Progress
PostPosted: Fri Jan 01, 2010 10:38 pm
Online
Here is the most likley final version of the pan. (except for adding the Bottom) - I will do that when I get a pickup to modify for this pan.
I added a dipstick Guide on the side of the pan - This should help Keep the dipstick away from the crank and Windage / Crank Scraper area.
I also completed the Top baffles / Drain directors.
Pics Below.
Dipstick Guide
Dipstick Guide again
Fowllowing Shots are baffling - The Big hole is for the pickup to fit through.
PostPosted: Fri Jan 08, 2010 7:42 am
Online
Well Here is some progress over the week.
I finally got the Block painted on the inside for smooth oil drainback.
I used Glyptal:
Crank Weight Is 75 ~ 75.5 Pounds
Crank installed
Rod caps for #'s 1 and 2
Pistons 1 and 2 are in.
PostPosted: Fri Jan 08, 2010 9:13 am
Looking good Greg!
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Jan 08, 2010 4:41 pm
Schweet! :D :D :D :D :D
 Post subject: Pan, Pickup Done 1-27-10
PostPosted: Wed Jan 27, 2010 8:10 pm
Online
Well Here are the most recent updates. The pan is all done except for a darin plug, and sizing the dipstick up. Pickup tube is legthened about 2 5/8" I also Need to leak test the pan.
After getting some work done with a pickup tube and level installed I had to cut quite a bit off of one side of the pan to get it to have a flat and level bottom. This required removing, and cutting / reinstalling the baffle so it sat level with the pan floor. So really the pan has more capacity but is only about 2.5~ 3" Deeper than stock with all the baffling.
O yeah I forgot Pistons, Cam and Crank / mains installed now too.
Need to get some of My Jeffrey parts and make a 2 Piece timing cover a'la Tilley style.
Pics Below.
Enjoy,
Crank In
#'s 1 & 2 In and mains buttoned up
From the top
Bottom End Done
Oil pump in
Tilley's timing gear With adjustability
Fitting oil pickup
Pickut Tube Final length
Finished pan shots minus drain plug
Trap Doors 1
Trap Doors 2
PostPosted: Thu Jan 28, 2010 7:32 am
Looks like great progress. Sounds like you'll have it out at Hagerstown?? Hope we can have another neck'n'neck heads up race.
Users browsing this forum: Greg Ondayko and 1 guest
