It is currently Thu Oct 08, 2026 10:26 pm
Post new topic  Reply to topic  [ 59 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Thu Dec 09, 2010 2:47 pm
...With the extra squirt hole in the con rods, will oil pressure be affected much?
The original spirt hole is blocked by the cast crank bearing (the hole is in a different place) and I did keep the size of the new hole the same.... so oil demand should be about the same.
I did reuse the "homemade" aluminum HV oil pump off Buster so there should be plenty of flow available.
PostPosted: Thu Dec 09, 2010 3:39 pm
You know stuff. Image
DRIVE IT,DON'T HIDE IT
PostPosted: Thu Dec 09, 2010 3:45 pm
Here are a couple of photos of that light weight cast crank installed into the early block.
No problems with the final crank installation... seeing that all the time and "pain" was covered during the mock-up stage and block clearancing work.
PostPosted: Fri Dec 10, 2010 6:38 pm
PostPosted: Sat Dec 11, 2010 9:58 pm
one word......SICK !!!!!
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Dec 12, 2010 5:32 am
Thanks Doug. And keep us posted. I am eager to see how this works out.
Sam
PostPosted: Sun Dec 12, 2010 5:58 am
I especially liked your caster wheel based set up. Very creative.
Don
Don
PostPosted: Mon Dec 13, 2010 9:07 am
Here are the "numbers" on this assembly:
3.475 Bore X 4.125 stroke (55 lb cast crank)
7.006 c to c factory 198 con rods, lightened to 535 grams.
KB # 268 pistons w/ 1.594 compression height & 18 cc "D dish".
The block had the deck cut just enough to true it up (.008) removed and the final assembly has -.024 deck height.
Steel shim head gasket (.020) to give a .044 quench zone.
54 cc head chamber & 40 degree intake closing point. (at .050 lift)
8.997 Static C/R and 7.71 DCR
Here what the assembled short block looks like:
PostPosted: Mon Dec 13, 2010 12:18 pm
Would be neat to see fuel mileage numbers on this one with EFI and a stick!
PostPosted: Mon Dec 13, 2010 5:11 pm
Why not put in a full groove main bearing so the rods see full time oiling (rather than pulsed) and call it a day.
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Dec 14, 2010 10:23 am
We always 'partially groove' the mains as standard practice, enough groove to get by the "parting line" and smoothly transition into the solid lower insert...
Here is a photo of the assembled long block... ready to install.
All the parts painted silver are 'recycled' from the Buster engine.
The car has "Dutra Duals" so the front exhaust manifold will have to be swapped-off the engine currently in the car and bolted onto this engine... as we do the R & R.
Time to get this unit into service!
PostPosted: Tue Dec 14, 2010 12:50 pm
Doc,
What do use to do that? I would like to try that on my next rebuild.
PostPosted: Tue Dec 14, 2010 1:02 pm
Doc,
PostPosted: Tue Dec 14, 2010 1:36 pm
I use a Dremel tool with a 1/32 cut-off wheel... then use a small triangle file to clean-up the entry.
We spent the time to make a bearing holder and "guide", with a locating slit in it. (An old main cap and a piece of 2.750 PVC pipe)
Put the bearing in the holder, place the guide over it, to protect the rest of the bearing surface and run the wheel thru the locating slit.
Remove "slitted" bearing, file the entry edge & deburr as needed.
It does take some time & a steady hand.
PostPosted: Tue Dec 14, 2010 1:45 pm
Bananas for the good Doctor. Image
Users browsing this forum: No registered users and 19 guests
