It is currently Sat May 16, 2026 5:24 pm
Post new topic  Reply to topic  [ 1346 posts ]  Go to page Previous 122 23 24 25 2690 Next
 Post subject: 4-25-11
PostPosted: Mon Apr 25, 2011 4:02 pm
No test-ntune runs yet. Too much rain here this april ;-(
It has been more than a Month since I tried to drive down to Hagerstown for a TNT session and they "closed" 'cause there were not enough Cars.
Maybe I will be able to get a test n tune in soon Here in Pittsburgh.
I have been Able to Remove the Rear Bumper, Some unnecessary Brackets and Supports and other metal where it's not Needed for another 27.5# Weight Reduction. Also Radiused the RR Wheel Well As I noticed some rubbing when I rolled ruster off the trailer.
Pics:
Bumper delete:
RR Wheel Clearance:
Glamour Shots of my new rear:
Ruster is Now 307.5# Lighter then last year!
I also was able to get the 4:56 gears in as well So I just need a track to open up around here!!!
PostPosted: Mon Apr 25, 2011 5:43 pm
Very cool Greg. :D
I was debating about putting a rear bumper back on GodsRods Duster II to make it look better, but I don't want to add back any weight.
Further down the list of priorities is using one of the plastic fascias for the front like you did... They're still sitting in the bed of the truck... :lol:
I know what you mean about RAIN!! It really makes me want to move back to Arizona (even Germany didn't get THIS much rain!)
PostPosted: Mon Apr 25, 2011 8:27 pm
Looking real good.My car got alot better 60 fts by just removeing the clamps on the rear of the springs,and angeling the shackals forward a bit,think I added a half inch spacer to move the tops forward to get about 45 degree angle.Got even better after i added a short piece of leaf,mounted upside down from just behind axel forward.I have best results with no clamps,and pretty much flat springs.Think I have 1 less leaf than you.Just giveing you cheap easy ideas that has worked for me.Guzzi Mark
PostPosted: Mon Apr 25, 2011 8:45 pm
After re looking at pics,what are those rear shocks?I know you cant possibly bee running air shocks.competition engineering shocks work well for me and are affordable.Guzzi mark.
PostPosted: Tue Apr 26, 2011 5:49 am
Pretty sweet, Greg. See you in 3 weeks!
PostPosted: Tue Apr 26, 2011 7:25 am
Yep Shock rework is in the plan, but I need to get some runs in first for a baseline this year.
 Post subject: 4-30-11
PostPosted: Sat Apr 30, 2011 8:31 pm
I was able to Finally take the car out this year to the home track.
The day went very slow and only got 3 runs.. But better than nothing I guess.
Those of you who have attended a slant 6 race in the past at Pittsburgh know what I am talking about.. That slow race pace is the same.
A guy next to me said the air was 4000' today Accorgind to the reading on his weather station. I can't wait for good air now.
Here are the 3 runs:
Video of Run #3
http://www.youtube.com/watch?v=-PDtPckHnCM
The Fabbed up "kickdown Keeper" or "Kickdown Linkage Eliminator" worked great - No adjustments needed.
I took off the air shocks and put on some regular Shocks but never got to make a 4th run with the other shocks due to the tire rubbing the wheel lip and a massive oildown near the end of the night that sent everyone home.
I have to radius the Wheel opening more to try out these shocks.
Maybe another outing in a week or 2. :-)
PostPosted: Sun May 01, 2011 5:40 am
NIce job Greg.
Tom
11.02 @ 120.56
Chassis dyno
PostPosted: Sun May 01, 2011 6:57 pm
In the 12s next time out.Nice going.Mark
 Post subject: 5-2-11
PostPosted: Mon May 02, 2011 5:28 am
I got 5# out of the car yesterday by trimming the door frames and other areas such as seat belt mounting points and reinforciments for passengers. I just couldnt resist while I I had the metal tools out for the wheelwell job.
I will post some pics soon. I am going to trim up the driver door frame which should be good far another 1-2#'s
Also I need to Get some supports for under the hood, It's really flexing at the big end of the track. I think Some more pins or heater hose bits could be helpful in this area.
PostPosted: Mon May 02, 2011 5:49 am
Yep, 12s at Hagerstown...
Good start to the season!
PostPosted: Mon May 02, 2011 8:20 pm
Good job Greg. It will be great to have a few 12 second /6 cars at mason dixon this year!!
Ryan Covalt
PostPosted: Mon May 02, 2011 8:37 pm
Ryan: will Try my darndest to get in the 12's in 3 weeks - I like a challenge
Pictorial update:
Total Weight Loss since November 2010: 312.5#
Door Frame Hacking: Compare it to a stocker 1.5#'s there!
Rear Door hack:
Shoulder Belt Hack Passenger Side:
New RR Wheel lip Radius:
Will Be modding the drivers door in a similar fashion too.
 Post subject: 5-6-11
PostPosted: Fri May 06, 2011 2:38 pm
Well I was able to cut 5 More Pounds of metal out of the Driver's door and from the Trunk area:
Now I have lost 317.5# Out of Ruster since November 2010
I can probably find 100 More #'s by The end of summer.
I also got a chance to Shim up th rear of the hood as it was "squashing" or flattening a lot at the big end of the track.
I used some bits of old heater hose and some liquid nails to do the trick:
The beer can coolies are for when I put the hood on the roof so it dosent scratch too much.
I found out that I also need to spend some tine working on the LR wheel well now as I have a tire hitting and rubbing there now..
It's good because I most likely will have to cut some more metal out to get it to stop rubbing. :-)
I dont mind.
PostPosted: Sat May 07, 2011 12:08 am
Holesaw= FREE Hp.The next 100lbs are ALOT harder than the first 300.You are doing fantastic and it will pay off.I would love to see anouther 20lbs off the front.Start by cutting windows in the inner engine compartment.Lets air flow go tru and not build up resistance under the hood.I got big windows behind my shock towers.Guzzi mark
