It is currently Thu May 21, 2026 2:00 am
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 1 2 3 4 59 Next
PostPosted: Wed Aug 17, 2011 8:28 pm
Thanks Ryan but as for the carb goes it can't be turned I tried I even tried a offy intake carb plate the only way I could make it work is if I re drilled and tapped the intake
I haven't b put the motor under load yet till I install the BOV
I got a question thou are u running the stock pv or are u running brpv were are u boost ref them from the carb hat to where on the carb?
Here's a couple pics maybe somebody else can help if u don't no the answer Ryan thanks all!
There's a port bottom right on the pic on the base plate of the carb
I don't think this is the one
Pretty sure this isn't the correct one it was plugged off
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Wed Aug 17, 2011 8:39 pm
Tom can answer the PV issue. I have my PV blocked and run off of jet alone. The rear port on the carb is for the pcv.
Generally the plate that bolts to the intake plenum can be turned 90* for carb location. I could be wrong though, never had a Clifford shorty intake.
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Wed Aug 17, 2011 10:09 pm
Ryan is the valiant back together yet or is the turbo still out to the shop
Aaron
PostPosted: Thu Aug 18, 2011 5:10 am
I'm putting the converter back in sometime here soon. Hope to go racing in sept or oct.
PostPosted: Thu Aug 18, 2011 5:39 am
Sweet I'm sure u can't wait, realistically I might make it to the track once or twice but we will see keep me posted on the valiant!
Aaron
PostPosted: Sun Aug 21, 2011 5:39 pm
I'm still running a PV. The PV is boost referenced to the same place as the fuel pressure regulator.
I had to drill the carb main body to pressurize the port behind the PV and modify the PV to work in a reverse manner. This richened up the part throttle on the car from very very lean to good.
http://www.flickr.com/photos/18510442@N02/5119411932/" title="BRPV by dts223, on Flickr"><img src="http://farm2.static.flickr.com/1171/511 ... 90d5_m.jpg" width="240" height="180" alt="BRPV"></a>
Above is a pic of what I did to the PV to make it "referenced".
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Aug 26, 2011 5:09 am
Shaker I've read a boat load of write ups on modifying a stock pv in thus fassion but I can't find anything with regaurds to the clip holding the brpv closed under normally conditions I was able to find a small post about 3/4 copper pipe cap but nothing about boost ref the brpv in the fashion u did I have my Carb apart now I'm going thru it because I'd like to no exactly what I'm working with once I start my tuning process
thanks for the continued help
Aaron
PostPosted: Fri Aug 26, 2011 8:41 am
I had to had fab that bracket. You also have to remove the brass fitting and spring from the pv as well. To do this, heat the brass "nut" while the rest of the pv is submersed in water. You will then be able to remove the nut and invert it (with thread locker) for the intended purpose.
You will also need to get some nytriphil (sp) floats as well. The primary float will have to be modded to work with the extra space the BRPV parts take up.
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Aug 26, 2011 4:38 pm
Did u do the nickel brpv or just flip the retainer over what did u use for the bracket and the tip to hold the spring in place also if I boost ref the pv cavity via the base plate will that work for this mod?
Shaker I'm going through the hanger mod for the carb now just to make sure it was done properly and I ordered some floats and a pv plug for the secondary also the rear acc. pump dia. Was bad and the pv didn't have a spring so I decided to just go through the carb before I even start the tuning process I plan on taking notes and writing down everything for future ref
Thanks for the thousandth time
Aaron
PostPosted: Fri Aug 26, 2011 6:45 pm
I flipped the retianer over and used an old pv and scavenged parts from it to make a holder. The retainer is held in place by a screw. It is a common thread. You can adjust when the PV opens by using different springs...have to play with that. It is actually pretty simple.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Aug 28, 2011 2:10 pm
With aussiespeed large port gasket, you had the head, exhaust ported to the gasket size, what about the intake?
1963 Dodge Dart 170
PostPosted: Sun Aug 28, 2011 8:13 pm
Yes I did a rough port match of the intake along with the exhaust manifold
Aaron
PostPosted: Tue Dec 20, 2011 1:56 am
I'm working on a turbo header/manifold for the TOAD here's a couple pics the first three legs are tacked together
Image Image
 Post subject: getting closer
PostPosted: Wed Mar 21, 2012 8:31 pm
PostPosted: Wed Mar 21, 2012 8:49 pm
Badass man I love homemade headers thats what I get the most oogles about at car shows. I had a guy ask me tonight " Thas one of those skyline engines isn't in your duster!?" I said nope just a good ol slant six :)
What starter is that it looks small I that would help me mine is right against the downpipe.
Kev
