It is currently Fri May 22, 2026 5:15 am
Post new topic  Reply to topic  [ 1346 posts ]  Go to page Previous 152 53 54 55 5690 Next
PostPosted: Thu May 23, 2013 6:47 pm
Great to hear Greg!! :D
Hamilton/N. Wilkesboro next month..? :wink:
PostPosted: Thu May 23, 2013 7:02 pm
100% on the sickness. Do you still have a dash frame? Learned a lot from the racer crowd. A couple of them didn't wanna tell me the vehicle weight though :lol:
Glad you did not find any problems!
I used to run the 6x1 header and it worked pretty good.
I have No dash Frame - That's about 10-20#'s - I removed that when I took the windshield out and went Lexan.
PostPosted: Thu May 23, 2013 7:03 pm
That's The Plan. - We'll see if it holds together :-)
PostPosted: Fri May 24, 2013 7:06 am
Good news, Greg! Gee, I wish I had listened to your car now. I have heard that noise several times and it distinct from rod knocking.
Interested to see the header results....
PostPosted: Fri May 24, 2013 7:17 am
Thanks lou,
I wanted to save the parts so once I suspected rod knocking I even winched it up onto the trailer - Better to Be safe and Save a few bucks and have it turn out this way..
I have already learned my lesson with the Dart - I fried a rod and crank after running it with a "noise" in the motor.
PostPosted: Fri May 24, 2013 7:48 am
Greg, not sure why but I couldn't keep converter bolts tight on mine either. Tried 2 different transmissions, 3 different converters, and 3 flexplates. Red Loctite wouldn't even hold.
Hope you have better luck. :D
PostPosted: Fri May 24, 2013 8:16 am
I might Just take the bolts to my competent machinist and Have them drilled for safety wire... Then I'll tie them together with the wire and locktite :-)
PostPosted: Fri May 24, 2013 6:27 pm
Stage 8 fasteners makes torque converter bolts that utilize aluminum tabs and snap rings to positively lock them.
PostPosted: Fri May 24, 2013 6:40 pm
Another Good option.
Good to know and thanks for sharing, Seymour.
PostPosted: Thu May 30, 2013 4:33 pm
SSRN National Champion
Greg, My computer has been down a few days, so I didnt know about the good news till now. I have had converter bolts come loose a couple of times as well. Now Im always worried about them coming loose again even with locktight. Im glad Ruster is healthy.
Ron
PostPosted: Thu May 30, 2013 8:40 pm
Yep Should be all good.
I should get 2 local test sessions here at home before going to Wilkesboro...
I wanted to try out the Hooker Super comps and I also have a set of 4.88's Built on the stand that Maybe Will lower my ET? Possibly these would be for my 1/8 Mile setup?
Wee shall See.
PostPosted: Sun Jun 30, 2013 6:13 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
This is an addictive thread. I must have missed it but, how many point cage do you have? Chrome Moly? Where do you get one?
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
 Post subject: 7-2-13
PostPosted: Tue Jul 02, 2013 3:50 pm
The Kit I got Was a competition Engineering Kit. It's Chromemoly - Needs to Be TIG/GTAW welded in and you can learn alot of Fabricitating skills if you wish to take the task on yourself.
I suggest to Get a Tubing Notcher (woodward Fab/ Summit Has Cheaper ones) And at least a Hot / Chop Saw.
Here is a Link to where it is on this thread..
http://slantsix.org/forum/viewtopic.php ... &start=720
The Kit has 2 Part Numbers: Links Below
The Hoop (which is Pretty Specific to your car / application) and the Strut Kit which is somewhat more universal and will take time and a lot of cutting / Sanding Grinding to fit up correctly.
http://www.summitracing.com/parts/cee-3158
http://www.summitracing.com/parts/cee-3100
IN OTHER RUSTER NEWS...
I got the 4.88 Gear Set in - The 8.75 Chunks weigh 60# each - the 4.56's weighed the same as the 4.88's
The Hooker headers were also .2 Slower in the quarter Mile as compared to the Mopar Performance 6 into ones.. so I took those back off as well.
I will report back on the 4.88's to see if anything is quicker with those.
PostPosted: Tue Jul 02, 2013 4:41 pm
Thanks for the info Greg. I am surprised by the performance of the headers as well. I figured the Hookers would out do the Mopar ones. But it may depend on the combo??
PostPosted: Tue Jul 02, 2013 7:27 pm
It's Possible that it's the Combo.
The Mopar Performance ones are a bit shorter in where the collector area comes together... in other words the Primary tubes are shorter on them.
The hooker and Cliffords have about 2" Longer Primary Rubes.
I might be interested in making an even shorter set and seeing if that helps.
