It is currently Sun Oct 25, 2026 7:13 pm
PostPosted: Thu Sep 19, 2019 10:14 am
Car Model: 1966 Dodge Dart
I'd already pulled the oil pan once to weld in a bung for the turbo oil line. In hindsight, I should have put a new rear main seal in there then. Now I have the oil pan off a second time, and I'm not looking forward to dealing with those four separate gaskets all having to stay in place. Are there any one-piece gasket options? All I've been able to find are the Mahle / Fel Pro sets with cork side gaskets and rubber front / rear gaskets.
Matt Cramer
PostPosted: Thu Sep 19, 2019 11:18 am
The "Real Gaskets" guy from Tennessee has some kind of silicone oilpan gasket, but not one piece, I think. Maybe just the side rails in silicone? Hard to make a one piece one with this design... I use "The Right Stuff" gasket sealer on all surfaces and make sure to carefully pull the nubs through the pan (rear piece) and timing cover (front piece) with a needle nose pliers. If careful, you can do it w/o leaks. I get everything ready to go, make sure the pan and TC are straight, and then go for it (15 min of gooping/smoothing/sweating) to get it all bolted snug before the sealer dries. This has worked well for me for many pan jobs.
PostPosted: Thu Sep 19, 2019 1:08 pm
Well, I can tell you for a fact, I didn't use enough goop! :mrgreen:
PostPosted: Thu Sep 19, 2019 3:55 pm
The real gaskets... I tried them. Silicone side rails. Stock type front and rear gaskets near rear main and under timing cover. I bumped mine with a bit of solvent or thinner on tear down and it changed size. Went back to a regular 4 piece gasket.
Just goop it correctly and it will be okay.
I use black rtv and some time let it set for an hour before i tighten.. keeps some of the goop put and prevents squeezeout/ slide around.
PostPosted: Thu Sep 19, 2019 8:06 pm
You could try the Right Stuff gasket goo-goo....
PostPosted: Wed Sep 25, 2019 12:52 pm
Got the pan back on, RTV needs to dry. Let's hope the oil stays inside this time...
Matt Cramer
PostPosted: Fri Sep 27, 2019 5:52 am
Unfortunately, something went wrong. Hopefully I can just get a big gob of RTV on the back as I think it was the rear rubber seal that isn't doing its job.
File comment: Leak.
Matt Cramer
PostPosted: Fri Sep 27, 2019 8:46 am
Car Model: 1966 2D Dart
I have studied about this with my 66 Dart. If one leak will be fixed two more will be found soon. Every second bolt has been drilled to water/oil/brake fluid/wind shield cleaner reservoir/tranny fluid/rear end oil. Even wheel bolts seem to have be sealed...
PostPosted: Fri Sep 27, 2019 9:47 am
Looks like it was the oil pan gasket there and not the rear main seal, at least. I'll see if a blob of RTV is enough.
On second thought, probably better to just change out the gasket.
Matt Cramer
PostPosted: Fri Oct 11, 2019 4:55 am
Update - changed the gasket, looks like everything's OK.
Matt Cramer
Users browsing this forum: Google [Bot], Plymouth_Ruster and 8 guests
