It is currently Thu Jun 18, 2026 4:46 pm
Post new topic  Reply to topic  [ 361 posts ]  Go to page Previous 112 13 14 15 1625 Next
PostPosted: Sun Jul 12, 2020 10:23 pm
This is some very impressive work. Thanks for sharing!
PostPosted: Mon Jul 13, 2020 4:26 am
Lovin' it..
PostPosted: Mon Jul 13, 2020 4:41 am
Changing plugs will be the job of the passenger.
This truck should be fast and have traction problems.
PostPosted: Mon Jul 13, 2020 7:54 am
Reed, Lou, Greg, Thanks for following along.
Now that the cab can be dropped in place things are getting more complicated.
--> The Diesel Corvette <--
PostPosted: Mon Jul 13, 2020 5:32 pm
I can overlook the GM content because such fabrication skill deserves recognition.
My hat (welding helmet?) is off to you 8)
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Wed Jul 15, 2020 3:12 pm
Starting to rebuild the tunnel. Using as much of the material that was removed as I can to simplify the fabrication.
PostPosted: Wed Jul 15, 2020 5:55 pm
Nice,
That's exactly what I did when the T5 when into Grüne Hölle.
PostPosted: Wed Jul 15, 2020 7:31 pm
Nice,
It sure beats trying to shape and join a bunch of flat little pieces of sheet metal.
PostPosted: Thu Jul 23, 2020 7:03 pm
The expensive tubular K-member I bought early on turned out to suck up way too much ground clearance.
So, I chopped the offending chromoly stuff out
And built my own
Much better
PostPosted: Sat Jul 25, 2020 11:41 am
Wow! great work!!
PostPosted: Sat Jul 25, 2020 12:58 pm
Wow! great work!!
Thanks Rick!
PostPosted: Fri Oct 16, 2020 3:08 pm
The chassis is getting close to being ready for the real motor to go in. I originally had a 6 quart truck oil pan on it but the pan hangs down too low. I decided I'd chop up a couple of car oil pans I have to make one high capacity oil pan. The way I have engine placement in the S10 frame there is nothing under the engine so why not use that space to increase the oil capacity?
I suspect it's going to hold 12 quarts or so now. Overkill?
PostPosted: Fri Oct 16, 2020 6:04 pm
Excellent work. We A-body guys are envious of the area available...
PostPosted: Fri Oct 16, 2020 7:44 pm
Thanks Lou,
I've been getting a lot of sheet metal welding practice lately.
I'm still not good at it but I managed to avoid making a big mess!
PostPosted: Sat Oct 17, 2020 3:10 am
Double drains and 2 numbers on the stamping. I like it
