It is currently Mon Nov 09, 2026 3:33 pm
PostPosted: Mon Feb 21, 2022 6:09 am
I've searched this forum but didn't find the answer;
I'm planning to take the Dart out this summer to drive from The Netherlands, via the UK to the south of Ireland; a 1500mile round trip.
I don't question the car's capability to manage this distance, but I am more worried for my own back in this trip so the seats needs to be fitted with new foam.
I have taken out the front bucket seats and the rear bench to get new foam filling, but I'm wondering how to get the backrest out. It is attached on the top of the backside to the bag where the convertible roof is folded in.
How do I remove this?
Thanks in advance!
PostPosted: Mon Feb 21, 2022 8:11 am
Online
Hello Mr. Dutch Dart,
Welcome to our Slant 6 community!
Once you have the back seat bottom removed, look at the bottom corners of the backrest toward the outer wall of the car and the floor. There are triangular-shaped loops of steel rod on each corner facing downward, and they are held down strips of steel that are bent over the loops. Bend the strips (screwdriver then pliers is probably best) so that they are roughly perpendicular to the wheel housing. This will allow you to pull the triangular loop on the backrest corner loose (pull toward the front of the car). After this, pull upward on the backrest and it will come loose from the car. There are upward facing steel hooks that hold the backrest frame structure about 15 cm down from the top of the backrest and about 30 cm in from the side of interior panels.
I hope this helps and please ask more questions as they come!
Lou Madsen
PostPosted: Mon Feb 21, 2022 11:47 am
Wow I think this is a really clear description, but I just bended over backwards in the car and didn't find anything that even resembles a triangle shape thing. Tomorrow with daylight I'll clean the car, looks like there's about 58 yrs of sticky goo there. I bet my two kids are responsible for the upper layer.
If there's any picture or mechanical handbook that shows what it looks like, that'll be helpfull
PostPosted: Mon Feb 21, 2022 12:22 pm
Online
There might be factory body seam sealer (black goo) around or over the brackets I described. Take a putty knife or screwdriver and dig around at the very bottom outside corners of the backrest, where the fabric meets the metal of the wheel tub.
PostPosted: Mon Feb 21, 2022 4:47 pm
Is there any possibility that the rear seatback is attached differently on a convertible compared to a 4 door/ 2 door? Hard roof body?
It's been years since I have had a backseat removed on a convertible.
PostPosted: Tue Feb 22, 2022 8:38 am
guess what, it was way easier then expected...
when the seat is removed, there where just 2 bolts holding these iron strips in place right where the seatbelts are attatched (seatbelts are from the '70s, but they keep my kids (8 and 4yrs old in place).
after removing the 2 bolts it was simply slide upwards and take the back rest out. the roof-cover simply slides out to the side.
PostPosted: Tue Feb 22, 2022 12:27 pm
Online
Oh yeah, that is very different than the attachments on a sedan or coupe. Sorry I could not be of more specific help.
Happy Slant Sixing!
PostPosted: Wed Feb 23, 2022 5:48 am
what I don't understand is; it is not attached on the top. So wondering if there's some (heavy) luggage in the trunk, and you brake, wouldn't it just blast right through it?
PostPosted: Wed Feb 23, 2022 7:12 am
Online
Yes, that is strange. The sedans/coupes have bottom and top mounting.
PostPosted: Wed Feb 23, 2022 11:00 am
I don't know anyone that puts large amounts of weight or volume of cargo in their '64 Dart...
Not like anyone that I know hauls engine blocks around or anything in the trunk..... :lol: :lol: :lol: :lol:
PostPosted: Wed Feb 23, 2022 11:09 am
Online
Haha! I think my maximum was about 1600 lbs (+ driver) in the 68 Dart driving from WI to CA in 1996, still with 9" drum brakes... I've had over 1200 lbs in the 64 Dart before.
PostPosted: Thu Feb 24, 2022 12:32 am
I was kind of figuring that out; the car has 4 drum brakes... an emergency stop is out of the question...
Although I've had it on the highway at 80mph I didn't like to drive at that speed with it. Taking it 1500miles to Ireland this summer, through Wales, the UK, northwest of France, Belgium and The Netherlands will all be done by two lane express way's, scenic routes and even backroads. The max speed won't be over 60mph.
(This week though, I'll be skiing in Austria, flying the Autobahn through Germany at 140mph is better in a 2021 car as a 1964 car :roll: )
Still though, regarding the rear seat, it should be fastened on the top. Is there like a mechanic-book of the Dart that shows how it supposed to be?
