It is currently Sat Oct 24, 2026 7:27 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Jul 31, 2023 4:16 am
Car Model: 73 Dodge Dart Sport 198
Hi Dan,
After trying an aftermarket 318 BBD carb from China and facing the same idle stability issue (+new issue of flooding), I looked on the forum and found a guide to distributor rebuilding.
It then pointed me to a service gear needing pin hole adjustment when replacing to cancel excessive play on the drive shaft - I remember I didn’t do that procedure.
Rather than drilling new holes in the service gear, I simply have put back the original gear as it was in good shape. The idle issued has gone :)
Now I have a spare Chinese BBD, maybe I will reuse some parts of it later to pimp my remanufactured Rockauto BBD (any articles/thoughts on mixing a 318 BBD with a /6 BBD?) .
On this note thank you again for your and others assistance :)
Rad
Rad
PostPosted: Mon Jul 31, 2023 4:37 am
Does anyone has any pictures or diagrams how factory air intake flex hose should be routed and where connected from the air box on a super six option in an A-body in the 70's? Specifically in '73 Dart Sport models?
This seems to be the last element I have missing in my 198 to 225 super six conversion. Thanks!
Attached are pictures of my current engine bay without the hose.
Rad
Rad
PostPosted: Wed Aug 02, 2023 8:01 am
The A-Body never had a Super Six option, so there is no provision for the air hose off the air cleaner. On the F-bodies, the inlet was between the battery and the radiator, where it attached to a plastic pipe that had its inlet opening down by the bumper.
The Super Six air cleaner is nothing more then a 318 air cleaner with a fancy decal. You could always substitute the base from a early '70s 318 air cleaner to get a more period correct look.
Nice looking engine compartment.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 9 guests
