It is currently Sun Oct 25, 2026 10:39 pm
PostPosted: Tue Dec 19, 2023 3:06 am
Car Model: 1983 d150
I am doing a lean burn conversion on a 1983 d150 slant 6. Should a holly 1945 model 1975 Dodge truck work for laneburn conversion for this 1983 Slant six. On the carburetor I want to get it has the numbers r8994, 6049, 3118, 2029, 0833. I made a mistake this carburetor is not rebuilt by Holly it is remanufactured by Holly
PostPosted: Tue Dec 19, 2023 7:29 am
PostPosted: Tue Dec 19, 2023 7:47 am
I know this may not be in the cards right now, but going to a 2 barrel carb on these anemic engines makes a world of difference.
PostPosted: Tue Dec 19, 2023 7:49 am
all trans for cars 75-77 After market replacement not oem, not lean burn or manifold vacuum, might be ecomaster https://www.forabodiesonly.com/mopar/th ... rs.456595/ R 8994 AAA does your carb have the letters?
PostPosted: Tue Dec 19, 2023 8:30 am
Yes those are the same numbers on the carburetor I am buying
PostPosted: Wed Dec 20, 2023 7:41 am
with the letters
PostPosted: Wed Dec 20, 2023 7:47 am
Ecomaster
PostPosted: Wed Dec 20, 2023 7:48 am
from ebay https://www.ebay.com/itm/116013792549?h ... SwVxpbQSie
PostPosted: Wed Dec 20, 2023 10:29 am
Those Economaster 1945s are a really good score. They have all the updates and refinements (and fixes) absent in the '74-'76 1945s, plus more. They come with a lean main jet, but that is easily and inexpensively changed for a thoughtfully-chosen larger one, and then the engine will run great.
PostPosted: Fri Dec 22, 2023 4:28 am
That carb is still there, put it on Ebay watch list. Seller offered huge discout.
