It is currently Mon Jun 15, 2026 2:11 am
PostPosted: Mon Sep 09, 2024 7:11 pm
I have a 1983 d150 slant six with a ford 4 speed transmission not sure what type. I saw on ad on Facebook of this guy selling a New Process NP435 4-speed transmission manual with bell housing for Dodge flywheel, clutch, pressure plate, driveshaft, PTO (Power Take Off) gearbox. Included would this fit my slant six if not what would I need to do. He says it came from the factory on a 440. Also is this a granny transmission or would acceleration be quicker.
PostPosted: Tue Sep 10, 2024 6:36 am
No it won't fit. If it was on a 440 then the belhousing, flywheel...etc is different than a Slant 6.
PostPosted: Tue Sep 10, 2024 10:24 am
That NP435 was used in both Dodge and Ford
What "Ford trans" is in your truck?
The 435 had a removable bell housing, with the right bell housing and flywheel that trans could go behind a /6.
PostPosted: Tue Sep 10, 2024 4:02 pm
Could I get that all separately so it can fit
PostPosted: Tue Sep 10, 2024 4:03 pm
No clue all I know is that it's a 4 speed. Couldn't really ever find any information on it what used parts could I find for the transmission to fit.
PostPosted: Tue Sep 10, 2024 11:25 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
Your '83 D150 (2wd) slant would have had an A833OD 4 speed with super tall .71/1 top gear. Anything 4wd (W100 and up) and any D/W250, D/W350 would have had the A435 heavy duty trans with grannie 1st gear.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
PostPosted: Wed Sep 11, 2024 5:48 am
I really don't think it's the A833 I'll take pictures of it when I change out the throw out bearing. Because when I replaced the clutch I was told it wasn't a dodge but a ford clutch.
PostPosted: Wed Sep 11, 2024 5:52 am
Here are the bottom pictures If you can id the transmission.
PostPosted: Wed Sep 11, 2024 6:39 am
For sure not a 833 OD. That is a "top loader".
PostPosted: Wed Sep 11, 2024 7:16 am
I've been having issues trying to id the transmission. All I know is that it's a ford since it has a ford clutch in it.
