It is currently Mon Oct 26, 2026 5:36 am
PostPosted: Mon Nov 11, 2024 6:41 am
Replaced my throwout bearing in my 83 d150 now it's sticking and can't shift through the gears when I'm driving what did i do wrong. And how could I fix this.
PostPosted: Mon Nov 11, 2024 7:23 am
I doubt it is something with the bearing, although it could be.
Is it linkage or Hydraulic actuated? The theory is the same as your foot transfers motion to push the bearing on the pressure plate diaphragm or fingers lifting the pressure so the clutch disc can freewheel in the open flywheel to plate ring space.
I bet the linkage is maladjusted - Check the FSM for the procedure on setting freeplay on the linkage.
PostPosted: Mon Nov 11, 2024 7:27 am
Did the TO bearing have a plastic housing or a metal housing? If plastic, it might have broken. Numerous people have had trouble with the plastic parts. When I replaced the clutch in my 84 D-100 the clutch kit came with the plastic TO bearing housing. I called the company to complain, and they sent me a metal one at no charge.
PostPosted: Mon Nov 11, 2024 8:35 am
I'm pretty sure it's linkage since it looks like a rod is connected to the black fork that's on the TO.
What's is FSM
PostPosted: Mon Nov 11, 2024 8:36 am
It's metal all metal
PostPosted: Mon Nov 11, 2024 9:25 am
The FSM is the Factory Service Manual. They can include helpful procedural data and tests for things on our older vehicles.
PostPosted: Mon Nov 11, 2024 9:29 am
Does anyone happen to have one? An post a pic of the instructions on what to do.
PostPosted: Mon Nov 11, 2024 9:51 am
The clutch Freeplay adjustment with a linkage can be found Here
It's not for a 1983 Truck, but rather a 1970 Chrysler, but the concepts and procedures are roughly the same.
If following the procedure does not work, then there is a broken torque shaft or torque shaft support, or the Clutch fork pivot is broken or cracked, or some other unforeseen malady has occurred.
Both are unlikely, but I have had seemingly every part of the factory clutch linkage system fail on my various vehicles over the years. leaving me with the situation you describe.
PostPosted: Mon Nov 11, 2024 11:17 am
So if I understand the manual right I have to adjust the nuts on the clutch side of the truck so it's has a 5/32th free play? I never touched the top just the bottom or would it be best to touch the bottom so it has that free play. From the clutch fork side
PostPosted: Mon Nov 11, 2024 4:21 pm
Online
I'm not sure what your saying? Top? Bottom? There is only one adjustment point on the clutch and that is on the link between the torque shaft and the clutch fork. That is all I have ever seen. Adjust it until you have @ 1" free travel at the pedal.
PostPosted: Tue Nov 12, 2024 1:00 pm
Which is underneath the truck correct. Also could someone take a picture on how it looks stock because I know mine isn't stock
PostPosted: Tue Nov 12, 2024 3:55 pm
I love it! "Okeh, we'll send you real parts if you jump through the hoops and squawk loudly enough about the garbage that was in our box you bought". Tell me we're living in a crummy timeline without saying those words.
PostPosted: Tue Nov 12, 2024 4:47 pm
Online
Is this the truck with the Ford transmission you have been talking about? Then it could have had a Ford TOB not the factory Mopar one. Did you inspect the new one and compare it to old one?
PostPosted: Tue Nov 12, 2024 8:20 pm
Yes I did it was the exact same one. Might have changed some parts from the ram to the Ford transmission for it to work. We made a new shift linkage just because the old one was dent and had 8 nuts on it holding it in place that's the reason why I think it's that. I do know from the fsm it has a rubber gromet on their and maybe some other things. Not sure where though. Also this is what I'm working with i have about 1 inch play at the peddle. Haven't tried it out yet but the clutch seems hard and rough like it gets stuck not smooth.
