It is currently Fri Nov 27, 2026 9:58 am
Post new topic  Reply to topic  [ 32 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Jan 21, 2005 6:28 pm
Car Model: 1962 Lancer 770
you're right, that's the one. And wow--sucks on that whole ceramic paint issue. I think I will avoid that one like the plaque.
how bout it...price on MP paint? Dare I ask tooowice?
PostPosted: Fri Jan 21, 2005 6:59 pm
Cheapest I have found it is $7.99 a can ( I think).
I recommend these folks:
http://stores.ebay.com/Frederick-Dodge
They offer fast, friendly service.
D/W
If it ain't broke, fix it!
PostPosted: Fri Jan 21, 2005 7:49 pm
ok i'm checking them out...thanks dennis!
MJ
PostPosted: Fri Jan 21, 2005 7:50 pm
Dupli-color used to be good, but since they reformulated it ("ceramic"), it comes out way too gaudy and super-glossy looking.
D/W
I haven't had problems with Dupli-color. Yeah it's glossy out of the can, but I was just noticeing today that it dulled down to a nice satin finish.
You also have to recoat it in one hour or wait for it to cure for about 5 days, or it will "lift"
D/W
I've been known to fudge times and temps a bit. No problems yet... And it's only HALF as much as the MP stuff. (anyone else noticed that to be normal for dealership stuff - twice as much?)-zorg
PostPosted: Fri Jan 21, 2005 7:53 pm
how long have you had it on the engine zorg? Just curious...
PostPosted: Fri Jan 21, 2005 8:04 pm
... And it's only HALF as much as the MP stuff. -zorg
So is Plastikote. I didn't say Duplicolor totally sucked, just not my personal preference. I have used it in a pinch. I have tried to recoat it without the first series of coats being cured enough, and believe me, it is a mess! (like clean it up and start over). Also, their is virtually no difference between their "semi" and "hi-gloss black" (both extremely glossy), and their "low-gloss black" is really flat-black. There is no in between. Of course, just about all spray-bomb engine paint is way glossier than the original factory paint and that includes Plastikote, but it doesn't look quite as cheesy as Duplicolor (in my opinion). The MP stuff actually laid down real nice and has a nice sheen to it, so I was happy even though it was big $$$.
D/W
PostPosted: Fri Jan 21, 2005 8:07 pm
well sheesh, i know its 2x as much, but how many cans did you end up using? Total paint cost <$30? reliability is a good thing =) Being unhappy with the result a few years later = bad
PostPosted: Fri Jan 21, 2005 8:12 pm
Y'know what? I just remembered. The paint I had such terrific success with on my (now departed) '65's engine was NAPA Farm Equipment Enamel, which I believe at the time was made by Martin-Senour paints. Color was "International Harvester Red" (IH-RED) and it was an exact match for the original red engine color. It was very easy to work with, had very good coverage and resisted engine heat just fine.
PostPosted: Fri Jan 21, 2005 8:18 pm
And another thing: You're going to have to mod your radiator's top tank. The 170 had the inlet hose fitting pretty well near the center and uses a Gates 777 hose (simple "L" bend, as shown in the photos of the '62 Savoy you posted). The '61-'62 A-bodies with 225 are a really tight fit between top of engine and top of radiator, and there's not enough room for the L-bend hose while still allowing enough flexibility to ensure the rad isn't pulled apart as the engine moves around. They use a Gates 20450 and the inlet fitting is more towards the passenger side.
PostPosted: Fri Jan 21, 2005 8:24 pm
I've never really had a durability issue with any major brand engine paints. Some seem to be more susceptible to hot anti-freeze than others though. That will discolor them if it leaks or sprays on the finish and make it look like crap. After a few months of solid curing, it's usually more resistant.
D/W
 Post subject: Oil pans and pickups
PostPosted: Thu Jan 27, 2005 6:49 pm
This could throw a wrench into the works: I went through the '62 FPC and here's what I found under Oil Pickup Tube and Screen Assembly:
A-Body 170: 2121702
A-Body 225: 2206317
B-Body 225: 2206261
And under Oil Pan:
A-body 170: 2268446
A-body 225: 2268449
B-body 225: 2206463
So, it looks as if there are THREE different oil pans and THREE different pickup tube assemblies, depending not only on engine size but on vehicle chassis.
PostPosted: Thu Jan 27, 2005 7:13 pm
argh! So I'll just have to try it and see which one clears the K Member?
anyone have any idea what the differences between these three pans and pickups are?
MJ
PostPosted: Fri Jan 28, 2005 12:42 am
NAPA Farm & Equipment Caterpillar yellow is what I used to paint my slant:
It does have quite a gloss to it. If I keep the road dust & grime cleaned off, it still looks 'wet'. Engine has about 1000 miles on it now. It doesn't seem to be any worse for the wear yet, but it is still relatively new. :?
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Sat Jan 29, 2005 6:45 pm
That yellow surely looks nice on the engine. I like it better than the pale MP yellow.
What'd you do with the engine's tinware (timing cover, rocker cover, etc.)? Cadmium plate, or??? I see it's not painted.
PostPosted: Sat Jan 29, 2005 9:02 pm
On the valve cover, a year and a half or so, on my super six intake, two weeks. I just noticed it is starting to lose the gloss, and take on a nice almost matt finish. About the price difference: poor kids use cheap stuff... -zorg
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 6 guests
